Electrolysis of water and actual electrode potential.
The discussion revolves around the actual electrode potentials in an electrolytic cell during the electrolysis of water, particularly focusing on the voltage source and the resulting charge distribution on the electrodes. Participants explore concepts related to electrode reactions, charge accumulation, and the behavior of ions in the electrolyte.
  • One participant claims that the voltage source does not directly contribute to the potential on the electrolytic electrodes, but rather determines the current and adds charges to the electrodes.
  • The same participant proposes that for an electrolytic cell with carbon electrodes and sulfuric acid, the minimum voltage required for gas generation is 1.23 V, suggesting that the actual potential on each electrode is 0.615 V.
  • Another participant challenges this interpretation, agreeing that 1.23 V is the potential difference when gas starts to evolve, but argues that the absolute voltages on the electrodes cannot be simply divided as proposed.
  • This challenger emphasizes that the charges on the electrodes are not the same as the charges of the ions in the solution, suggesting that ions contribute to a double layer rather than being part of the electrode charge.
  • Further, a participant introduces the analogy of charging a capacitor, noting that the potential difference does not imply equal distribution of voltage across the electrodes.
  • Another participant adds that the situation involves two double layers, indicating a more complex interaction than a simple capacitor model.
Participants generally agree on the potential difference of 1.23 V being relevant for gas evolution, but there is significant disagreement regarding the interpretation of electrode potentials and the nature of charge on the electrodes. The discussion remains unresolved with competing views on these concepts.
Participants express uncertainty regarding the definitions of charge on electrodes and the implications of the electric double layer, indicating that assumptions about reference points and charge distribution may affect interpretations.
Phy1
For an electrolytic cell, the voltage source Vs, does not contribute directly to the potential on the electrolytic electrodes. Vs determines the current and can add charges to the electrodes. This can be observed when charging supercapacitors and is discussed in these threads :
https://www.physicsforums.com/threads/supercapacitor-charging-voltage.594372/
https://www.physicsforums.com/threads/ultracapacitor-charging-voltage.680719/
Question:
What is the actual potential on the electrolytic electrodes for the electrolysis of water?
Example:
An electrolytic cell has carbon electrodes (make them identical commercially available activated carbon supercapacitor electrodes, so a charge has to build up for a few seconds) and sulfuric acid H2SO4 electrolyte.
Positive charge electrode reaction: 2 H2O(l) → O2(g) + 4 H+(aq) + 4e− 1.23 V
Negative charge electrode reaction: 2 H+(aq) + 2e− → H2(g) 0.00 V
1.23V is the minimum Vs should be for hydrogen and oxygen generation to start in this cell.
(There are many factors that increase this value, but use 1.23V for this example.)
Charge is added to each electrode in equal amounts. The actual potential on each electrode for this cell is (1.23V/2)=0.615V. The positive charge electrode is +0.615V and the negative charge electrode is -0.615V. The electrodes are is series, so the potentials add to 1.23V. Breaking the charge down further: the positive charge electrode has (+0.3075 charge and -0.3075 ionic charge from SO4-2) and the negative charge electrode has (-0.3075 charge and +0.3075 ionic charge from H+)
Is this correct?
Chemistry news on Phys.org
Phy1 said:
Is this correct?
No.
You are more or less right about 1.23 V being the potential difference between the electrodes when the gas starts to evolve. After that you are mixing several different concepts in a way that I fail to understand (but the mix is definitely wrong).
Just because the total voltage is 1.23 V doesn't mean absolute voltages are ±0.0615 V.
Charges on electrodes are not these of the ions in the solution. Ions are attracted to the charged electrodes, that's one of the reasons why they migrate in the solution, but their charge is not part of the charge of the electrodes. If anything they neutralize the electrode charge becoming part of a double layer on the surface.
Hi Borek,
If you like, the terms can be changed from positive charge electrode to electrolytic anode and negative charged electrode to electrolytic cathode.
Think of charging a regular capacitor. If you charge a capacitor to 2V then the positive plate gets +1V and the negative plate gets -1V. When the capacitor discharges, the potential difference is 2V. The electric double layer forms a capacitor and the ions form half of the charge.
Depends on what you assume to be the reference point. What if one plate is at 60 V (measured against the ground) and the other at 62 V (again, measured against the ground)?
There are two double layers, one on each electrode, so if anything, the solution acts as a two capacitors in the row.
  • · Replies 16 ·
