Electrolyte and salivary amylase
  • Thread starter Thread starter oli
Salivary amylase requires chloride ions for activation, but experimental results indicate a higher enzyme activity with KCl compared to NaCl. The discussion raises the possibility that the difference in enzyme rates could be related to the solvation properties of KCl versus NaCl, with a suggestion that KCl may dissociate more effectively in solution. There is also a recommendation to conduct an experiment using both KCl and NaCl together to determine if one of the salts negatively impacts the enzyme's reaction rate in either solution. This could provide further insight into the observed differences in enzyme activity.
oli
i know that salivary amylase needs to be activated with chloride ions. yet from my experiment, it seems that the enzyme rate is higher when using KCl rather than NaCl. any suggestions why?
Chemistry news on Phys.org
Could it have to do with solvation of KCl vs NaCl? That is a very wild guess :)
meaning that KCl would dissociate quicker than NaCl?
Maybe, it might be negligible though with such ions which dissolve in water very well, but you could just look up the dissociation constants of both?
Did you try the experiment where you add both KCl and NaCl, to see if maybe there is something negatively influencing the reaction in either solutions?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
