Electromagnetic buzzer project help
The discussion focuses on building a DC electromagnetic buzzer for a school project, highlighting issues with the connect/disconnect mechanism of the buzzer. The user experiences persistent sticking of the nail to the tin can, resulting in weak vibrations. Key solutions include improving electrical connections, utilizing springs for better contact force, and optimizing the magnet's distance and flux path. Recommendations emphasize using a horseshoe-shaped magnet for enhanced performance.
  • Understanding of basic electrical circuits
  • Familiarity with electromagnet principles
  • Knowledge of mechanical components like springs
  • Experience with magnetic flux concepts
  • Research how to improve electrical connections in circuits
  • Learn about the design and application of springs in mechanical systems
  • Investigate the properties of horseshoe magnets versus straight magnets
  • Explore techniques for optimizing magnetic flux paths in electromagnets
This discussion is beneficial for students, hobbyists, and educators involved in electronics projects, particularly those focused on electromagnetism and mechanical design.
soleiletlune
hi, i have to build an dc electromagnetic buzzer for school project, but I'm having tons of trouble! can anyone offer advice to help me out? (like good websites with instructions or pointers?) i have most trouble with the connect/disconnect part of the buzzer! i have this nail that is fixed in between an electromagnet and a tin can and everytime it touches the tin can its supposed to complete the circuit, and the electromagnet is supposed to become magnetized and attract the nail towards it which thus disconnects the circuit. this makes the electromagnet become demagnetized again and cause the nail to fall back towards the tin can and complete circuit. this process is supposed to keep repeat, but my nail persistently stays stuck towards the tin can and kind of just vibrates weakly. any ideas on how to make the disconnect/connect more pronounced and fluent?
I think you need to make the magnet stronger.
This might be caused by a poor electrical connection between the nail and the can. You can check that by moving the electromagnet away and seeing if it's just as strong when powered through the nail/can as when it's connected directly to the power supply.
Real buzzers use springs rather than gravity, so they may provide a higher contacting force and less electrical resistance.
It could also be that the magnet is too far away from the nail.
Also consider the flux path for the magnet. Does it easily reconnect in a loop? Using both ends of a horseshoe shaped magnet would be much stronger than one end of a straight one because the flux doesn't have to go so far through air.
  • · Replies 20 ·
  • · Replies 23 ·
  • · Replies 16 ·
