Maximizing Power and Arrangement of Electromagnets in a Gauss Gun
The discussion centers on optimizing electromagnets for a Gauss gun project, specifically replacing permanent magnets with electromagnets. The user successfully created a basic electromagnet using a 1/2" by 2" bolt and magnet wire powered by a 9V battery, capable of suspending steel balls. To enhance performance, it is crucial to activate multiple electromagnets sequentially rather than simultaneously, as the magnetic field strength is proportional to current. The user seeks advice on timing mechanisms for activation and potential switch designs to automate the process.
  • Understanding of electromagnet principles and construction
  • Basic knowledge of electrical circuits and current flow
  • Familiarity with coilgun mechanics and design
  • Experience with timing mechanisms and switches for automation
  • Research "coilgun timing circuits" to automate electromagnet activation
  • Explore "5 amp power supply options" for enhanced electromagnet strength
  • Investigate "electromagnet switch designs" that can be activated by projectiles
  • Study "coilgun construction techniques" for optimal electromagnet arrangement
This discussion is beneficial for high school physics students, hobbyists interested in electromagnetism, and anyone looking to build or optimize a Gauss gun project using electromagnets.
burtonlang
For a high school Physics project, I am supposed to create an electromagnetic device (like a generator, a motor, a Magnetohydrodynamic boat, etc.) I was thinking about building a Gauss gun, but was wondering if I could replace the individual magnets with electromagnets. I have a bunch of 1/2" by 2" bolts, and I have access to a bunch of magnet wire. I coiled wire around one of the bolts until it was about an inch in diameter, and hooked it up to a 9v battery. It's magnetic, and is able to suspend about two or three 1/2" steel balls in a vertical line. What do you suggest to make my electromagnets more powerful, and how should I arrange them to work optimally in a Gauss gun?
Any suggestions at all? It's not firing, but all the electromagnets work individually. What might I be doing wrong?
You need at least two preferably more electromagnets in a line, and you need to activate them one after the other, with the activated section of magnets just ahead of the projectile during the firing. If you turn on all the magnets at once then basically nothing will happen.
The magnetic field strength is proportional to current, so get your hands on a 5 amp power supply and shield your wires from skin contact.
I have five in a row, right now. What do I need to do to activate the magnets at different times? It would be rather inconvenient to manually flip a switch for each magnet at the exact right time... Is there some kind of switch I can use that the ball can activate without causing too much (better yet, any) decrease in speed?
Yes, the plan is to build something exactly like those, with electromagnets.
Actually, the Science-Fair-type-thing that this was for was yesterday, and I ended up just building an ordinary Gauss gun, using steel bearings and neodymium magnets. It was extremely successful and was one of the most popular projects. However, I would still like to build the electromagnetic equivalent.
What kind of switches should I use so that the balls activate the electromagnets?
Excellent. This clarifies your efforts. I have to go to work, but should be back tomorrow or the next day and will try to help.
  • · Replies 43 ·
  • · Replies 37 ·
  • · Replies 22 ·
  • · Replies 42 ·
  • · Replies 17 ·
