What is the current in a wire loop outside a solenoid with a changing current?
The discussion revolves around calculating the induced current in a wire loop located outside a solenoid with a changing current. Participants explore the implications of the magnetic field generated by the solenoid and its effects on the loop, addressing both theoretical and practical aspects of electromagnetic induction.
  • Some participants express confusion about the magnetic field outside the solenoid and its relevance to the induced current in the loop.
  • There is a suggestion to neglect the contribution of the magnetic field outside the solenoid and only consider the field inside for calculating induction.
  • Participants question the validity of using the magnetic field inside the solenoid for a loop that lies entirely outside it.
  • One participant recalculates the induced current using the radius of the solenoid, suggesting that the magnetic field only applies inside the solenoid.
  • Another participant provides a mathematical expression for the induced electromotive force (emf) that includes areas inside and outside the solenoid, while approximating the external magnetic field as negligible.
  • There are varying results from calculations, with one participant initially obtaining an incorrect induced current before correcting their approach.
Participants do not reach a consensus on the treatment of the magnetic field outside the solenoid and its effect on the induced current in the loop. Confusion persists regarding the application of Faraday's law in this context.
Participants highlight limitations in their understanding of the magnetic field's behavior outside the solenoid and the assumptions made in their calculations. There is also a dependence on the definitions of magnetic field regions and their contributions to the overall induction.
MermaidWonders
A 2000-turn solenoid is 2.0 m long and 15 cm in diameter. The solenoid current is increasing at 1.0 kA/s.
(a) Find the current in the 10-cm-diameter wire loop with resistance 5.0 $\varOmega$ lying inside the solenoid and perpendicular to the solenoid axis.
(b) Repeat for a similarly-oriented 25-cm-diameter loop with the same resistance, lying entirely outside the solenoid.
I did part (a) fine, but I'm currently stuck on (b). There shouldn't be a very weak magnetic field outside the solenoid, right, so how can I find the values of the initial and final magnetic fields and the solenoid current outside it? If this isn't necessary, then how can I work around Faraday's law ($\varepsilon = -\d{\varPhi}{t}$) to get the new current of the wire loop?
Suppose we neglect the contribution of the magnetic field outside the solenoid?
So we only consider the magnetic field inside the solenoid to find the induction in the loop outside the solenoid.
Sorry, but I'm totally confused here. :( So how come we consider the magnetic field inside the solenoid when the loop lies entirely outside it? Can you please explain?
We have $\varepsilon = -\d \Phi t$. This applies to all of the magnetic field that passes through the loop. And that includes the magnetic field that is inside the solenoid, while the part outside the solenoid is presumably negligible.
Wait, but the loop lies outside the solenoid... So sorry, but I'm still confused here. :(
How about not letting ourselves be stopped by that, but just do the math?
I don't know how to go about doing this calculation, but when I did the math assuming that everything else is the same, I got 12 mA as the induced current, which is the wrong answer (I got that by just changing the radius of the loop). :(
OK... I just recalculated this, but I used the radius of the solenoid (15 cm / 2 = 7.5 cm = 0.075 m) this time around, since this 25-cm-diameter loop has a greater diameter than the solenoid, and since the magnetic field only applies for inside the solenoid. I got 4.4 mA this time, which is correct. My reasoning probably makes no sense whatsoever, but can you please explain why?
Good! (Happy)
We have:
$$\epsilon = -\d \Phi t = -\d {(B_i A_i + B_o A_o)} t\approx -A_i\d {B_i} t $$
where $A_i$ is the cross sectional area inside the solenoid, $B_i$ is the magnetic field inside the solenoid, $A_o$ is the remaining area outside the solenoid, and $B_o\approx 0$ is the magnetic field outside the solenoid and inside the loop.
This is what we have in a loop outside and around the solenoid, where we neglect the reverse magnetic field, which we can as long as the loop is small enough.
I like Serena said:
Good! (Happy)
We have:
OK, makes sense now. Thanks!
