Electromagnetism - Boundary conditions for Polarization field at interface
The discussion focuses on deriving the electrostatic boundary conditions for a polarization field at the interface of two media with different relative permittivities. The user outlines their approach using a Gaussian surface and Amperian loop, referencing Feynman's lectures for guidance. They derive the relationship between the polarization fields in the two media and establish boundary conditions based on the continuity of the electric field and the displacement field. The user seeks verification of their derivation and questions whether their substitution of the polarization field is appropriate for the problem. The conversation emphasizes the importance of understanding boundary conditions in electromagnetism and optics.
lmcelroy
Not actually a homework question, this is a question from a past exam paper (second year EM and optics):
Use a Gaussian surface and Amperian loop to derive the electrostatic boundary conditions for a polarization field P at an interface between media 1 and 2 with relative permittivities εr1 and εr2.
D = ε0E + P,
\nabla.P = -ρb
where D is the displacement field, E the electric field and ρb the bound volume charge density.
Lack of a solution is the reason for posting?
Thanks in advance.
Ok, after obtaining a copy of Feynman's lectures and referring to Volume 2, Chapter 33-3, I think I have found a solution.
Treating the boundary as a separate region (media 3 with a relative permittivity that begins at εr1 and changes continuously to εr2) then since the P field is different in each region, in region 3 (the boundary) there is a \deltaPx/\deltax where Px is the P field in the x direction. So;
d/dx (Dx) = d/dx ( (ε0Ex) + (P)) ... (partial derivatives with respect to x [can't use latex very well]
D doesn't change in materials so:
-d/dx (Exε0) = d/dx (Px)
Integrating each side with respect to x over region 3 and letting P2 be the polarisation in εr2 region and P1.. :
Px2-Px1 = -ε0(Ex2 - Ex1)
Also there is no B divergence from Maxwell so:
B1 = B2 (for all directions)
Also from Maxwell:
curl(E) = -dB/dt (again partials)
Which gives the following set:
dEz/dy -dEy/dz = -dBx/dt
dEz/dx - dEx/dz = -dBy/dt
dEy/dx - dEx/dy = -dBz/dt
The E field only changes in the direction so only the following is considered:
dEz/dx = -dBy/dt
dEy/dx = -dBz/dt
Now if E were to change the right hand side of the equation would have to be balanced by a change of B with respect to time which does not happen so:
Ez1 = Ez2 and Ey1 = Ey2
So I have the boundary conditions of a dielectric interface. The boundary conditions on P are then just found by substituting P = E(εr-1)ε0:
(1) Px2-Px1 = -ε0(Ex2 - Ex1)
Px2 - Px1 = (-Px2/(εr2-1))+(Px1/(εr1-1))
Px1εr1 / (εr1-1) = Px2εr2 / (εr2-1)
(2) B1 = B2
(3) (P1/(εr1-1))y = (P2/(εr2-1))y
(4) (P1/(εr1-1))z = (P2/(εr2-1))z
Hoping someone can verify this for me. Fairly sure about the derivation of boundary conditions; it is essentially Feynman's derivation modified for two materials (he does it for vacuum to material).
However, not sure if the substitution of P is the right thing to do - does this form constitute an answer to the question or is it asking something else?
Again thanks in advance.
