Electron and positron collision producing a b0 meson pair
The discussion centers on the collision of electrons and positrons producing B0 mesons, specifically addressing the conservation of energy and momentum in this context. The threshold energy for the production of B0 mesons is established at 1.6 GeV, with the total energy in the lab frame being 10.6 GeV, given the electron's energy of 9 GeV. Participants clarify that the threshold energy refers to the minimum energy required in the center of momentum frame, and they emphasize the importance of using energy-momentum conservation equations to solve for the velocity and mean distance of the B0 mesons. The final calculated distance for the B0 mesons is confirmed to be 2.49 x 10-4 m.
  • Understanding of conservation of energy and momentum in particle physics
  • Familiarity with four-vectors and invariant mass concepts
  • Knowledge of B0 meson properties and production thresholds
  • Basic principles of relativistic physics and time dilation
  • Study the application of four-vectors in particle collisions
  • Research the properties and decay mechanisms of B0 mesons
  • Learn about relativistic energy-momentum conservation equations
  • Explore the implications of threshold energy in particle physics experiments
Particle physicists, students studying high-energy physics, and researchers involved in collider experiments will benefit from this discussion, particularly those focused on meson production and energy conservation principles.
physconomics
Electrons and positrons collide head-on with beam energies 9GeV and E respectively, producing B0 and anti-B0 mesons at the threshold energy. The B0 mesons undergo decay with a mean proper lifetime of 1.5 × 10−12 s. Calculate the mean distance that the B0 mesons travel before decay, as observed in the rest frame of the laboratory. (Neglect rest-mass energies of electron and positron)
E^2 = p^2c^2 + m^2c^4
E = ymc^2
P = ymu
Conservation of Energy: 9GeV + E = 5.3GeV + 5.3GeV
Therefore E = 1.6GeV for the threshold energy.
How would I find the velocity of B0 mesons so that I can calculate their mean distance?
Then it would just be distance = velocity of b0 * mean proper lifetime
Right?
Are you sure about that? What happened to conservation of momentum?
PS If the meson are created with their rest energy, then their speed is zero and they wouldn't go anywhere.
I'm confused doesn't the question say they're created at the threshold energy?
Yes, but the threshold energy is only the rest mass energy in the centre of momentum (COM) frame. In any other frame it is higher.
If the question said that the electron and positron had the same energy, then the lab frame would be the COM frame and each would have an energy of ##5.3GeV##.
If the positron has an energy of ##1.6GeV##, then the system has significant momentum in the lab frame, hence must have residual KE in the lab frame (conservation of momentum).
PS I guess the question may be ambiguous as by "threshold" energy it means the "minimum/threshold" energy, given that the electron has an energy of ##9GeV##.
Nevertheless, there clearly is no solution at a total energy of ##10.6GeV## - given the electron has ##9 GeV##. And, even if there were a solution with no residual momentum/energy, the mesons would be at rest and would travel no distance.
Hint: don't worry about calculating the threshold energy. Just trust the energy-momentum conservation equations.
Ah okay, I see, thank you! I've used four vectors and then the invariant to get E = 3.12GeV. I think I've got the second part too, using conservation of energy and time dilation. Thank you! :)
What answer did you get?
I got 2.49x10^(-4)m
physconomics said:
I got 2.49x10^(-4)m
Yes, that looks correct!
  • · Replies 21 ·
