Electron double slit experiment
The discussion focuses on the electromagnetic fields associated with electrons in the context of the electron double slit experiment. Participants assert that the electromagnetic field is uniformly present, and in the deconstructive regions of the interference pattern, the fields from electrons cancel each other out due to symmetry. The Heisenberg uncertainty principle is emphasized, indicating that electrons cannot be localized to specific positions. Quantum Electrodynamics (QED) is suggested as a necessary framework for analyzing interactions involving electrons and atoms in these regions.
  • Understanding of the Heisenberg uncertainty principle
  • Familiarity with quantum mechanics concepts
  • Basic knowledge of Quantum Electrodynamics (QED)
  • Concept of electromagnetic fields and their interactions
  • Study Quantum Electrodynamics (QED) principles and applications
  • Explore the implications of the Heisenberg uncertainty principle in quantum mechanics
  • Investigate the concept of symmetry in electromagnetic fields
  • Research the electron double slit experiment and its interpretations
Physicists, students of quantum mechanics, and anyone interested in the foundational principles of quantum theory and electromagnetic interactions.
Danyon
Is there an electric or magnetic field from the electron present in the deconstructive regions of the electron interference pattern?
The electromagnetic field is everywhere, there is nothing special going on in the darker (deconstructive) regions seen in an interference pattern.
I mean if I placed an electron in the deconstructive region would it experience a force from the electron that's being fired through the slits?
Electrons are not point particles. The Heisenberg uncertainty principle forbids them being placed anywhere since that would mean it has a definite position and momentum.
Thanks
Bill
Thanks
Bill
Okay, say the electron is trapped in an atom which is in the deconstructive region, the atom experiences a dipole moment, during that dipole moment does the electric field from the electrons being fired through the slits effect the atom? or is the electric field at the deconstructive region canceled out?
Again - atoms are quantum objects and QED would be necessary to analyse your situation.
But, due to the symmetry of the situation, there wouldn't be any electric field - at any point what's on one side will cancel the other - think about it.
Thanks
Bill
Thanks
Bill
Sorry I don't follow, could you explain further about the symmetry.
Say you have two negative charges and have a positive one in the middle. Now its obvious that the fields of the charges cancel in the middle and nothing happens to the positive charge. Interestingly you don't have to evoke that - simply use symmetry. Say if you are in front of the charges it goes to the right. Now go to the back of the charges - its exactly the same situation physically - but now it goes to the left. But since its physically the same it can't do that. It must therefore not move. This is a symmetry argument and in some cases its all you need to solve a problem. The same thing happens with your situation. Imagine you are in the middle of a trough and view it from the front and back - its the same - so - guess what - there will be no field. The same if you are in a crest.
Something for you to think about - does this happen if you are not on a crest or in a trough or if you move to the edges of the pattern.
Thanks
Bill
  • · Replies 20 ·
  • · Replies 32 ·
  • · Replies 36 ·
  • · Replies 26 ·
  • · Replies 60 ·
