Electron in the double-slit experiment
The discussion revolves around the nature of electrons in the context of the double-slit experiment, specifically whether the electron that leaves the source is the same one that hits the detection screen. Participants explore concepts of indistinguishability, quantum trajectories, and the implications of these ideas on our understanding of particle behavior in quantum mechanics.
  • Some participants assert that electrons are indistinguishable, making it nonsensical to ask if the electron that left the machine is the same as the one hitting the screen.
  • Others argue that if electron emission is slowed down for individual detection, it may make sense to consider the possibility of it being the same electron, although this is not guaranteed.
  • One participant suggests an analogy of electrons "bumping" into each other, questioning whether the electron hitting the screen is the one that was initially fired.
  • Another participant references Brian Greene's explanation of Feynman's formulation, which states that particles take all possible paths simultaneously, expressing confusion over this concept.
  • There is a discussion about the implications of language and precision when discussing quantum mechanics, particularly regarding the notion of a single electron versus multiple interactions.
Participants express both agreement and disagreement on various points. While some agree on the indistinguishability of electrons, others challenge this view by introducing scenarios where it might be reasonable to consider the same electron. The discussion remains unresolved regarding the interpretation of electron behavior and the implications of quantum mechanics.
Participants highlight the limitations of their understanding and the complexity of the concepts involved, particularly regarding the nature of quantum trajectories and the implications of indistinguishability in particle physics.
  • #31
I think we can say at this time, with a high degree of confidence, that in a double slit experiment the electron passes through one slit. This experiment has been reproduced at macroscopic scale by Yves Couder and Emmanuel Fort. Take a look at this article:
Single-Particle Diffraction and Interference at a Macroscopic Scale
Phys. Rev. Lett. 97, 154101 – Published 13 October 2006
https://hekla.ipgp.fr/IMG/pdf/Couder-Fort_PRL_2006.pdfThe relevance of Couder's experiment to quantum mechanics is theoretically justified here:
Emergence of Quantum Mechanics from a Sub-Quantum Statistical Mechanics
Gerhard Grössing, Int. J. Mod. Phys. B, 28, 1450179 (2014)
https://arxiv.org/pdf/1304.3719.pdf
A movie depicting the experiment can be found here:
Too bad Feynman didn't live to see this.
Andrei
  • #32
mike1000 said:
If they would have put detectors at each slit would the diffraction patterns have been observed on the detection screen?
That would be a great experiment to see.
mike1000 said:
Also, is the observed scatter of electron positions on the detection screen caused by the uncertainty in the electrons momentum which was inducted when the experiment attempted to localize the particle when it went through the slit?
The phase of the electron is what causes the pattern. The wavelength of an electron (how quickly the pattern repeats) is a function of the speed of the electron. Think of the electron as going through periodic changes as it flies through space. How much it "diffracts" around corners is a function of the "phase" (where it is in the wave function) of that electron.
  • #33
That is not in any meaningful sense a "reproduction" of the quantum-mechanical double-slit. It's a completely different physical system governed by completely different physical laws and that happens to display interestingly similar behavior so is interesting as an analogy. Considering the ubiquity of the wave equation in physics, it is not surprising that such analogies exist - but an analogy is never the real thing. Thus, you may feel a high degree of confidence, but you shouldn't expect others to share it.
"Justification" is also much too strong of a claim. There's nothing wrong with Grössing's suggestion that quantum mechanics might emerge from a realistic non-local hidden variable theory of the sort that he is considering (although without a candidate theory there's only so far it can be taken), and Couder's analogy suggests one picture of what such a theory might look like. But that's not a theoretical justification, it's an idea about one possible area of exploration.
  • #34
I think you are downplaying this a lot. Sure, interference experiments based on waves have been performed since Newton's time, but this is the first experiment to show interference effects with single particles outside quantum physics. Feynman thought it was impossible to imagine a classical mechanism for obtaining such a result, yet there it is.
I was under the impression that Grössing's proposal is local after all and what he calls "systemic nonlocality" does only refer to the influence of boundary conditions upon the particle. But it seems you are right, so I will retract my claim regarding the importance of his work in regards to Couder's experiments.
  • · Replies 20 ·
  • · Replies 36 ·
10K
  • · Replies 32 ·
  • · Replies 24 ·
