Electron moving between 2 charged plates
The discussion centers on calculating the acceleration and final velocity of an electron moving between two charged parallel plates with a specified electric field. The initial attempt at finding acceleration used the formula A = (E*Q)/M, yielding an acceleration of -2.11 x 10^13 m/s² in the negative j direction. For the final velocity after a displacement of 1.4 cm, the calculations also resulted in -2.46 x 10^6 m/s in the j direction. Ultimately, the user discovered that their calculations were correct, but the system was not accepting the input format they used. This highlights the importance of adhering to specific input formats in online systems for accurate results.
juggalomike
at some instant the velocity components of an electron moving between two charged parallel plates are vx = 1.20 105 m/s and vy = 3.70 103 m/s. Suppose that the electric field between the plates is given by Evec = (120 N/C) jhat.
(a) What is the electron's acceleration in the field?
-2.11*E13 m/s2 jhat Incorrect
(b) What is the electron's velocity when its x coordinate has changed by 1.4 cm?
1.20*E5 m/s ihat + -2.46*E6 m/s jhat Incorrect
F=ma
F=E*Q
V*T=D
V_0+A*T=V_1
Rearranging the above equations i get A=(E*Q)/M
so A=(120*1.6*10^-19)/(9.1*10^-31)=2.11*10^13 jhat in the negative direction
Because acceleration is in the J direction there is no Iforce, so I is constant. so for D=t*V or t=d/v t=.014m/1.2*10^5=1.17*10^-7
then V_F=V_I+A*T so V_F=3.7*10^3+-2.11*10^13*1.17^10^-7=-2.46*10^6
Yet all of my answers are incorrect, what am i doing wrong?
Never mind, my answer was correct but the system wasn't accepting the format i was inputting it as(which is ironically the format they fed the information to me in)
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 28 ·
