Electron speed due to magnetic field.
The problem involves electrons emitted from a device moving in a circular path within a uniform magnetic field. The magnetic field strength is given as 10 MN/C, and the radius of the circular path is 2.0 cm. Participants are exploring how to determine the speed of the electrons based on this information.
  • Participants discuss the relationship between magnetic force and centripetal force, referencing Newton's second law. There are attempts to clarify the meaning of the units provided for the magnetic field and whether they align with standard definitions.
There is an ongoing exploration of the definitions and units related to the magnetic field and electric field. Some participants suggest that the given unit for the magnetic field may be incorrect, while others attempt to reconcile the units with known physics principles. Guidance is offered regarding the conversion of units and the application of relevant equations, but no consensus has been reached.
Participants are questioning the validity of the unit MN/C for the magnetic field, as it typically should be in tesla. There is also mention of potential confusion arising from the use of different unit systems, such as CGS.
sarahaha288
electrons emitted by a certain device are observed to travel in a circular path with a radius of 2.0cm when plaves in a uniform magnetic field whose strength is 10MN/C. What is the speed of the elctrons emitted by this device?
I know that 10MN/C is "b-bar" as it is called in the book. But I'm not sure what equation to use.
I attempted to use the equation Fm=q(velocity/c x B)... but I am not sure what to use for the magnetic force.
im not really sure about it , but i think that since these electrons are moving in a circular path in a uniform magnetic field , then using Newton's 2nd Law :
qvB = m v^2/R
Yes, the magnetic force provides the necessary centripetal force for the circular motion of the electrons.
Fm = q (v X B) = m*v2 / r
Don't really know much about b-bar. The units should be either Tesla or Gauss.
I believe that if the given value 10MN/C ( 10 mega Newton per coulomb) , then this given value is the electric field (E) ..
the B-bar is measured in tesla. and if the electric field vector is the one that is given, how do I find the magnetic field in order to use the equation Fm=mv^2/B if i am trying to solve for v??
In your question, it said that "uniform magnetic field whose strength is 10MN/C" but for me that doesn't make sense? how it is a magnetic field with this unit, I know that it should be tesla, weber per meter square or volt.second per meter square but not Newton per coulomb ? can you please check the question once more ?
The magnetic field for B-Bar is definitely 10MN/C
the book says that vector B is in units of tesla which is: (N/C)(m/s^-1)
I don't really get you! what B-Bar supposed to mean is it the same as B?? and what is M(in 10 MN/c) ? , I am sorry if I can't be helpful but if you could clarify these questions then I may can help ..
RoyalCat said:
Are you working in CGS units by any chance?
In that case, refer to this wiki page:
http://en.wikipedia.org/wiki/Lorentz_force#Lorentz_force_in_cgs_units
This makes sense in terms of magnitude too, since B fields are usually only a fraction of a Tesla in strength, whilst here the numerical value for the field is on the order of 10^7!
I have checked the link you provided, but I can't see where it mentions that both E and B can be expressed in N/C unit? and I don't think that is possible for two different quantities to have the same units even if different system ..
If it is really mentioned somewhere then I apologize , and please quote from where it is mentioned .. & thanks
That is the whole point of the CGS system. :) [tex]\vec B[/tex] is defined differently there, so that [tex]\vec B[/tex] and [tex]\vec E[/tex] have the same units. The Lorentz force in CGS units would be:
[tex]\vec F=q(\vec E+\frac{\vec v}{c} \times \vec B)[/tex]
See the link for the exact transformations in going from one unit of measurement to the other.
hmmm I have never encounter this before .. thanks for bringing this up :) .. and I hope that sarahaha288 would be able now to solve the problem , it is just converting back B to tesla and then substituting in qvB = m v^2/R to get v ..
thanks so much! that helped a lot.
  • · Replies 25 ·
  • · Replies 31 ·
