Electronic Circuits-Compute voltage gain for OP-amplifiers
  • Context: Engineering
  • Thread starter Thread starter beyondlight
    Electronic Gain Voltage
5 replies · 3K views
beyondlight
We got the following circuit:
http://tinypic.com/view.php?pic=1zl7xg2&s=6
u_in is input
u_ut is output
I assumed that the upper amp has voltage u_in on the positive terminal.
And that the lower amp has voltage 0 V on the positive terminal.
then i calculated u_ut but the ratio then becomes: u_in/u_ut = 0
Because the current from the upper amplifiers output terminal to the output terminal u_ut is
i=u_in/2R
which then gives us
u_ut=u_in -(i*2R) = u_in -u_in
the right answer should be -1
help please.
So this is how i did it:
On the positive input for the 3rd amplifier we have v_x/2.
And i suppose that the voltage on the output terminal of the upper amplifier is v_x+u_in
The current through the resistor then becomes:
[tex]i=\frac{\frac{v_x}{2}-(u_{in} + v_x)}{R}[/tex]
Then the expression for the output u_o is:
[tex]u_o=\frac{v_x}{2} - R*i = {\frac{v_x}{2}-\frac{v_x-2u_{in}-2v_x}{2R}*R}[/tex]
after simplifying we obtain:
[tex]u_o=-v_x-u_in[/tex]
u_o/u_in = -1 (if v_x = 0)
Have i done correct?
Which resistor? Which direction?[/color]
[tex]u_o=\frac{v_x}{2} - R*i[/tex]
If we use your above expression for i, then the "-" here should be "+"
It is for the resistor after the output of the upper-most amplifier. I thought the current goes out of this amplifier and ends up at the output. So then it should be "-"
But i re-calculated this task with my method again, and got a quite different result. That turned out to be correct. I calculated without adding v_x.
The same current: i=(u_in/R)
u_out=0-Ri= -R(u_in/R)=-u_in
The gain then becomes -1.
I think this is sufficient.
