Electronic transitions for natrium atom
3 replies · 3K views · last reply
rayman123
Hi! I am writting my labbraport on electronspektrum for natrium atom.
Here is my electronic transitions but the teacher says that there are some transitions missing...have no clue which ones they might be...can someone explain to me what is he talking about? which are the missing electronical transitions which are not marked on my scheme?
my scheme:
thanks
  • Energy level diagram for sodium with the vertical axis labelled E, showing levels 3s at the bottom, then 3p, 4s, 3d, 4p, 5s, 4d, 5p, 6s, 4f, 5d, 6p and 7s rising upward, with lines drawn from 3s to several upper levels.
Well, what rules did you use to determine which transitions are allowed and which ones aren't?
[tex]\Delta l=+1,-1[/tex]
[tex]\Delta S=0[/tex]
OK, well, for starters, there are several states in your diagram which have no transitions at all. That implies that an electron in that state would be stuck there permanently - but hopefully that doesn't seem right to you. Start by looking at those.
For what it's worth, unless I miscounted (which is certainly a possibility), there are 29 transitions allowed by your rules that you haven't indicated in your diagram.
