Electrostatic force using vectors
4 replies · 3K views · last reply
pcleary
Charge A is +2C and is located at <4,0,0>
Charge B is +12.5C and is located at <0,-3,0>
What is the the Force(AonB)
What is the magnitude of F(AonB)
F = (k)(Qa)(Qb)/(r^2) (r^)
For reference the answers are
< -0.8k, 0.6k, 0 > N (F vector)
and
1k N (magnitude)
So I am confused as to how to solve this problem. I don't know if maybe it is worded strangely or what but I am not getting those answers.
I did a lot of these problems but not with vectors. How do you apply the answer you get into a vector. The equation is given as r(hat) after the regular F equation. Does this mean I distribute my answer into i+j+k? I am assuming the answer to that is no because that makes no sense mathematically.
This is not a homework problem it is a practice problem. I am trying to learn physics and would really appreciate if someone could explain how you apply your F into vector notation and how this particular problem can be solved so I can learn. I am sure it is something simple that I am just not getting and my teacher didn't explain properly (in class we never did any with vectors).
and
1k N (magnitude)
Yes, you need to write up the force in x,y,z components F=Fxi+Fyj+Fzk, or <Fx,Fy,Fz>
The vector "r^" is the unit vector pointing from A to B when you want the force exerted by charge at A to the charge at B. The vector pointing to B from A is the difference of the position vectors r=rB-rA=<0,-3,0>-<4,0,0> (or rB-rA=-3j-4i). You need to divide this vector with its magnitude to get the unit vector r^. "r" means the magnitude of the vector r.
ehild
Ah that makes a lot more sense now. So the reason I am finding the unit vector is I need a vector that is pointing in the same direction as the Force caused by these two charges.
Whenever I see r hat from now on that is referring to the unit vector, correct?
Problem worked out perfectly after that. I really appreciate the help.
Also just for clarification. If the question had asked for the F (BonA) or F_BA it then the difference would be the unit vector being composed from A - B or <4,-3,0> and of course the magnitude would be the same (5).
So the F_BA would have been <4/5 ke, -3/5 ke, 0>
Could you explain why that is the case? As in why would two positive charges cause one to go in the positive X (AonB) and the other in the negative X (BonA) direction? And why are would both have the same Y component? I just want to get a better understanding of what I am doing. I hate to memorize formulas and plug things in I would rather understand the concept.
Once again thank you very much for the explanation I truly appreciate it.
Correct.
or <4,-3,0>
Check your arithmetic. :smile:
As a reality check, remember Newton's Third Law of Motion. The force that B exerts on A must be equal in magnitude and opposite in direction to the force that A exerts on B.
Ah you're right. Thank you it all makes sense now! I really appreciate both of your help.
