Electric Potential: Find Distance/Ratio of Charges
  • Thread starter Thread starter pmd28
    Potential
The discussion focuses on calculating the distance between a positive charge +q1 and a negative charge -q2, given two points where the electric potential is zero. The first point is 3.35 cm to the left of -q2, and the second point is 7.65 cm to the right of -q2. The relevant equation used is V = kq/r, where V is the electric potential, k is Coulomb's constant, q is the charge, and r is the distance from the charge. The participants explore relationships between the charges and the distances to derive the ratio |q1|/|q2|.
  • Understanding of electric potential and electric fields
  • Familiarity with Coulomb's law and the equation V = kq/r
  • Basic algebra for solving equations
  • Ability to interpret physical diagrams of charge configurations
  • Study the concept of electric potential and its applications in electrostatics
  • Learn how to derive and solve equations involving multiple charges
  • Explore the relationship between electric potential and electric field strength
  • Investigate graphical methods for visualizing charge interactions and potentials
Students studying physics, particularly those focusing on electrostatics, as well as educators looking for practical examples of charge interactions and potential calculations.
pmd28
A positive charge +q1 is located to the left of a negative charge −q2. On a line passing through the two charges, there are two places where the total potential is zero. The first place is between the charges and is 3.35 cm to the left of the negative charge. The second place is 7.65 cm to the right of the negative charge.
(a) What is the distance between the charges?
(b) Find |q1|/|q2|, the ratio of the magnitudes of the charges
V=kq/r
I don't know where to start. I know that I need to solve for the distance between +q1 and the spot 3.35 cm to the left of the negative charge to be able to solve for the distance between them. I'm just not sure how to use the charge to the right of -q2.
Start by drawing a diagram of the setup. Label the distance between the charges as d.
What equations can you write to describe the given conditions?
See that's the thing, I'm still iffy on the relationshiphs. My best educated guess would be:
Since V @ .0335m is equal to zero. That would mean the net electric field at that point is also 0 because E=-ΔV/Δs.
Or am I going in a completely wrong direction.
You can work with the electric field or the potential. The potential is simpler as it is a scalar value that depends only on the charge and the distance from it. Since the problem statement specifically mentions potential, that would suggest that potential is a likely way to proceed :smile:
What's the expression for the electric potential at a distance r from a charge q?
V=kq/r
pmd28 said:
V=kq/r
Yes, that's correct. So write expressions for the potential at the two given locations assuming that the distance between the charges is d.
Ok, sorry I had a spark of genius. And I've been kind of going with it. I just want to know if I'm on the right track. I set the +q1 charges equal to each other and got:
r=.11/(V1-V2)
Then I set the -q2 charges equal to each other and got:
.035V1=.0765V2
Substitute to get
r=.11/(V1-.035V1)
I got stuck again. I need one more equation, but I just can't seem to find it.
r=.11/(V1-V2)
.035V1=.0765V2
Substitute to get
r=.11/(V1-.035V1)
You'll have to explain the above in detail. I don't understand what the equations are meant to represent. In particular, what are the "+q1 charges" and "-q2 charges"? The problem statement mentions only two charges, +q1 and -q2. And the potentials of interest are both zero.
The problem states a "-q2" not a "+q2".
Nvm I solved it. Thanks :D
