Solve Eletrostatic Problem: Sphere Charge Q0
  • Thread starter Thread starter Anonymous119
The discussion revolves around solving an electrostatic problem involving a charged sphere with charge Q0, situated in a vacuum inside and air outside with a small conductivity s. The user initially attempts to derive the charge evolution over time, Q(T), and arrives at a differential equation relating the charge to current. After some clarifications and corrections, the final solution is derived as Q(t) = Q0 * e^(-t * s/e0), indicating an exponential decay of charge over time. Participants also discuss the relevance of Maxwell's equations and Gauss's Law, noting the simplifications made for a high school-level problem. The conversation highlights the importance of current density and electric field relationships in solving the problem.
Anonymous119
[Note from mentor -- this post was moved here from another forum]
Hi,
I ran to this problem today and i try to solve it but i can't complete it so if anyone can help me :)
Sphere has a charge Q0. Inside the sphere is vacuum and outside the air. Consume that air has small non zero conductivity s (the inverse of resistivity=1/ρ=s). Find how its charge
will evolve with time Q = Q(T).
Here is my work:
Q(T) = Q_0-dQ(T)
dQ=\int_0^T I(t)\, dt
where is I=U/R
R=1/s *l/S where l= dr(distance betwen our sphere(r) and sphere (r+dr)) where dr is very small and S=4pi*r^2
U=kQ(t)*(1/r-1/(r+dr))
When i arranged this i got:
I(t)=Q(t)*s/e0 so
dQ=\frac{s}{e_0} \cdot \int_0^TQ(t)dt
Q(T)=Q_0-\frac{s}{e_0}\cdot\int_0^TQ(t)dt
Where e0 is eletric constant.
And now i don't know how to solve this equation.
So please if anyone know how or see any mistake in my work post here.
Thanks !
Anonymous119 said:
Hi,
Here is my work:
Q(T) = Q_0-dQ(T)
dQ means infinitesimal change of the charge, dQ=(dQ/dt) dt= Idt. Do not use d for finite changes. The change of charge can be written as ΔQ.
And you do not need ΔQ. You need the charge as function of time, Q(t).
Anonymous119 said:
where is I=U/R
I(t)=Q(t)*s/e0
Correct so far.
Anonymous119 said:
so
[STRIKE]dQ=\frac{s}{e_0} \cdot \int_0^TQ(t)dt [/STRIKE]
The current is equal to the charge leaving the sphere in unit time. I=-dQ/dt.
So ##dQ/dt= - \frac{s}{ε_0}Q(t)##
That is a separable differential equation for Q(t). You can write it
$$\int{\frac {dQ}{Q}}=- \frac{s}{ε_0}\int{dt} $$
Perform the integration and fit to the initial condition Q=Q0 at t=0. If you want definite integral from t=0 to t=T you an write $$\int_{Q_0}^{Q(T)}{\frac {dQ}{Q}}=- \frac{s}{ε_0}\int_0^T{dt} $$
ehild
Likes 1 person
Hm to solve this problem we just use ohm's law and the definition of current? Shouldnt somewhere use maxwell's equations? Wouldnt the charges flowing from the sphere to the outer imaginary spheres alter the electric field because the overall charge density changes in the volume of air around the sphere and not only in the surface of the sphere... But let me guess, we just neglect the charge density of the surrounding volume of air (as well as considering quasi static approach neglecting the terms dB/dt and dE/dt) in order to simplify the problem.
It would be better to use the relation between current density and electric field ##\vec j = σ \vec E## (The OP uses the notation s for σ, the conductivity. )
Integrating around the surface of the sphere, we get the current ##I =\int{\vec j d \vec A} = σ\int {\vec E d\vec A }= σ Q/ε_0##. The current is the charge flowing through a surface in unit time - the surface is a sphere concentric with the original one: I=-dQ/dt.
ehild
Correct so far. The current is equal to the charge leaving the sphere in unit time. I=-dQ/dt.
ehild
I think you are absolutely right .
I got confused about the marks how dumb.
THANKS !
I got this for the final solution:
$$Q(t)=Q_0\cdot e^{-t\frac{s}{e_0}}$$
I don't think so because it's problem for high school students and they usually don't study Maxwell's equations. I've just finished the first grade of high school so i don't know enough math to unerstand Maxwell's equations completely.
Excellent!
ehild
ehild
Ok i see so we can say that we use Gauss's Law as well.
But, suppose we want to calculate the charge density in the surrounding volume after time t, how we would proceed?
  • · Replies 30 ·
