Eliminate Parameter with Sin and Cos
  • Thread starter Thread starter Mikeylikesit182
    Cos Parameter Sin
The discussion focuses on eliminating the parameter \( t \) from the parametric equations \( x = 2 - \pi \cos t \) and \( y = 2t - \pi \sin t \) within the interval \( -\pi \leq t < \pi \). Participants conclude that while complete elimination of \( t \) is not possible, a single equation relating \( x \) and \( y \) can be derived. By rewriting the equations and squaring them, the resulting equation resembles that of a circle with radius \( \pi \), although it is clarified that the graph itself is not a circle.
  • Understanding of parametric equations
  • Knowledge of trigonometric identities, specifically \( \sin^2 t + \cos^2 t = 1 \)
  • Ability to manipulate algebraic expressions and equations
  • Familiarity with derivatives and their applications in finding slopes
  • Explore the geometric interpretation of the derived equation involving \( x \) and \( y \)
  • Learn how to find intersection points of parametric curves
  • Study the implications of derivatives in parametric equations
  • Investigate the conditions under which parametric equations can represent closed curves
Mathematics students, educators, and anyone interested in parametric equations and their applications in geometry and calculus.
Mikeylikesit182
x = 2 − π cos t
y = 2t − π sin t
−π ≤ t < π
I understand how to eliminate parameter using sin^2 + cos^2 = 1.
I can't figure out how to deal with the "2t" in the y equation, if you solve for sin(t) and square, you get
((2t-y)/π )^2 which leaves the parameter. Is there a way to get it into the argument of sin?
I need this to then figure out intersection points and tangents later. Thanks in advance for any insight!
Mikeylikesit182 said:
x = 2 − π cos t
y = 2t − π sin t
−π ≤ t < π
You will not be able to completely eliminate ##t##, but you can use these 2 equations to write a single equation that depends on ##x,y## and ##t## (but not ##\sin t,\cos t##). There is an interesting geometric interpretation of the equation that we can discuss after you try to find it.
Thank you for the help! I can't figure what that equation would be ( I can see one involving arccos and substitution but I think that would be a dead end.)
I thought maybe finding the derivative dy/dx for the parametric eqn and realizing that at the point of intersection the 2 slopes would be dy/dx and -dy/dx might lead me closer?
Using the derivatives might be of help later, but for now do something simpler. Rewrite the equations in the form
$$\begin{split}
x -2 & = -\pi \cos t, \\
y -2t & = -\pi \sin t\end{split}$$
and then square both and add them (you were close to this in your original attempt). Can you interpret the resulting quadratic equation?
$$\begin{split}
(x-2)^2 = (pi^2)(cos^2(t))
(y-2t)^2 = (pi^2)(sin^2(t))
added =
(x-2)^2 + (y-2t)^2 = (pi^2)(cos^2(t)) + (pi^2)(sin^2(t))
(x-2)^2 + (y-2t)^2 = (pi^2)[(cos^2(t)) + (sin^2(t))]
[(x-2)^2]/(pi^2) + [(y-2t)^2]/(pi^2) = 1
It seems to look like an ellipse adjusted upwards by the parameter? I really appreciate the help!
Correct. To be precise, it's actually a circle with radius ##\pi##.
So it seems at this point to find where the graph would intersect itself, we would ask what value for t would give us 2 sets of identical x,y coordinates?
Actually you want to find values ##t_1## and ##t_2## for which ##( x(t_1),y(t_1))=( x(t_2),y(t_2))##. In this case there is only one pair of such ##t_1,t_2##, but in general there can be more.
Also, I should warn that the graph itself is not a circle, despite the appearance of that equation above.
9K
