Eliminating the Euler Angle singularity without quaternions?
5 replies · 7K views · last reply
James_Frogan
Hi all,
I've formulated using Lagrangian formalism the equations of motion for a spinning top. I know about the gimbal lock/singularity that occurs at theta=0 and I was wondering if there was any other way to do it without dwelving into quaternions.
Yogi published a paper "A Motion of Top by Numerical Calculation" suggesting a replacement: [itex]\dot{\beta} = \dot{\varphi} cos \vartheta[/itex] and [itex]\dot{\alpha} = \dot{\varphi} sin \vartheta[/itex], but this hasn't worked for me (I find myself getting [itex]\ddot{\alpha} = 0[/itex], which isn't true)
I've had a look at quaternions but I'm not inclined to understand it or be able to simply 'convert' my equations over into quaternion calculus, neither (I believe) can I use Lagrangian mechanics on quaternions.
One way to avoid the problem without using quaternions is to lock the possible values of theta to a given range that doesn't include the singularities. For example, theta cannot be smaller than 1E-6 degrees and larger than 179.99999 degrees. But the simplest way is using quaternions.
M.
Thanks Mbert, unfortunately the case I am looking at causes the top to rise to the steady position.. which unfortunately is the theta 0 position.
Looks like I'll have to dwelve into quaternions. Is it possible to 'convert' my equations in Euler angles into quaternions if I have the equations in Euler's (rigid body) equations? Or must everything be redefined again?
To convert from Euler angles to quaternions take a look at this website:
http://www.flipcode.com/documents/matrfaq.html#Q60"
Especially the part:
Q60. How do I convert Euler rotation angles to a quaternion?
Converting Euler rotation angles to quaterions can be achieved through
the use of quaternion multiplication. Each rotation angle is converted
to an axis-angle pair, with the axis corresponding to one of the
Euclidean axii. The axis-angle pairs are converted to quaternions and
multiplied together. The final quaternion is the desired result.
The following code segment demonstrates this:
quaternion_from_euler( QUATERNION *q, VFLOAT ax, VFLOAT ay, VFLOAT az )
VECTOR3 vx = { 1, 0, 0 }, vy = { 0, 1, 0 }, vz = { 0, 0, 1 };
QUATERNION qx, qy, qz, qt;
quaternion_from_axisangle( qx, &vx, rx );
quaternion_from_axisangle( qy, &vy, ry );
quaternion_from_axisangle( qz, &vz, rz );
quaternion_multiply( &qt, &qx, &qy );
quaternion_multiply( &q, &qt, &qz );
M.
Thanks Mbert, I came across several articles on how to convert the angles themselves to quaternion, however the equations of motion are in the forms of: [itex]\ddot{\phi},\ddot{\psi},\ddot{\vartheta} = f(\phi,\psi,\vartheta,\dot{\phi},\dot{\psi},\dot{\\theta})[/itex], so I cannot apply the conversions in that manner.
Does Lagrange formalism work on quaternions?
