EMF & Circuits Homework: Solve for Vab
  • Thread starter Thread starter rasmusuperfan
    Circuits Emf
The discussion revolves around a circuit problem involving a variable resistor, a battery with internal emf and resistance, and measurements taken with an ammeter and voltmeter. Participants are tasked with determining the voltage across the variable resistor when it is set to a specific value.
  • Participants explore the relationship between the readings of the ammeter and voltmeter, questioning how to derive the internal emf and resistance from the given data. There is discussion about the implications of an ideal voltmeter and the concept of a voltage divider.
Some participants have provided guidance on how to approach the problem, suggesting that the values of emf and internal resistance can be determined from the measurements. Multiple interpretations of the circuit's behavior are being explored, particularly regarding the voltage divider concept.
There is a specific condition mentioned where the resistance R is set to 6.00 ohms, which is central to the problem being discussed. Participants are also navigating the implications of ideal components in the circuit.
rasmusuperfan
In the circuit (http://i.imgur.com/II38M.jpg),a variable resistor R is connected across the terminals of a battery, and an ideal ammeter and ideal voltmeter are also connected. In the figure, E is the internal emf of the battery, and r is its internal resistance. All the connecting cables have no appreciable resistance. The ammeter reads 3.10 A when the voltmeter reads 5.08 V, and the voltmeter reads 15.0 V when the ammeter reads 0.00 V.
Vab = E - IR
I thought since an ideal voltmeter has infinite resistance, so there would be no current through the resistor. I thought it should just be 15V then, but I feel like I am missing something. Any guidance would be greatly appreciated, thanks.
What, precisely, were you asked to determine? It looks to me like you're in a position to determine both E and r.
I am sorry, don't know how I forgot the most important part. It asks when R = 6.00 ohms, what is the reading of the voltmeter
If you knew the values of E and r, then when R is made 6.00 Ω you can calculate the voltage across it (it'll be a simple voltage divider circuit). So, can you think of how you might determine E and r from the given data?
Well, V = E - Ir, would you solve for r to be 5.08V = 15V - 3.1A*r? And I am sorry, but I don't quit get what you mean by a voltage divider, they split evenly?
Yes. You can find r that way. I see that you've also decided that E = 15V (the open circuit voltage across the battery). That's correct.
A voltage divider using resistors is a series connection of two resistors, with the "output" voltage taken across one of the resistors. So, if you had resistors R1 and R2 connected to a supply voltage V, and the output was the potential across R2, then
Vout = V*R2/(R1 + R2)
This follows from the fact that the current through the series connected resistors is V/(R1 + R2), so the voltage across R2 must be R2* V/(R1 + R2).
Awesome, thank you so much for all the help. That makes perfect sense, sorry I was confused. You really helped out a lot, have a great day
  • · Replies 17 ·
