EMF Oppsition in Adjacent Wires +/- Swing
  • Context: Graduate
  • Thread starter Thread starter Fluxation
    Emf Swing Wires
This discussion focuses on the behavior of electromagnetic fields (EMF) in a two-conductor "figure eight" wire configuration connected to a push-pull audio amplifier. It establishes that the current reversal in each conductor does indeed cause the EMF to oppose twice each cycle. To mitigate this effect, the use of differential mode driving is recommended, as well as the potential application of blocking capacitors or isolation transformers for practical use. The conversation emphasizes the importance of understanding inductance and the benefits of bifilar windings in reducing unwanted inductance.
  • Understanding of push-pull amplifier operation
  • Knowledge of electromagnetic fields and their interactions
  • Familiarity with differential and common-mode signaling
  • Basic concepts of inductance and bifilar windings
  • Research differential mode driving techniques for audio applications
  • Explore the use of blocking capacitors in audio signal paths
  • Study isolation transformers and their role in audio systems
  • Learn about inductance reduction methods, particularly bifilar winding techniques
Audio engineers, electronics hobbyists, and anyone involved in designing or troubleshooting audio amplifier systems will benefit from this discussion.
Fluxation
Can someone please help with this thought experiment? I have sought advice elsewhere but it remains unclear to me.
I have a straight piece of two conductor "figure eight" wire (like speaker wire or US power cord) laid out left to right.
I connect the output from a push-pull type audio amplifier across each conductor, but with the active and ground reference wires on opposite ends for each. Let's assume series resistance so no dead short.
As I understand, at any given moment (apart from crossover) the current in each conductor will be moving oppositely to the other, thus causing their respective EMF's to oppose.
My question relates to the fact that the push-pull output swings both plus and minus relative to ground.
1. Does this current reversal cause the EMF to oppose twice each cycle?
2. If so, is there any way to prevent this, e.g. with a blocking capacitor or isolation transformer? Please explain how in practical use.
Without a sketch or schematic, I could only guess at your question. Could you please sketch the circuit on paper and post a (clear, bright) cellphone picture using the UPLOAD button in the Edit window? You can Upload PDF or JPEG copies of the picture.
Also, the output of a push-pull amplifier can only swing negative if its power supplies include positive and negative rails (or if the output is capacitively coupled).
I have prepared a diagram but don't see any way to upload local content.
If you mean the icons in the gray bar at the top of the text entry window, I find nothing that reads "upload". I can add an image but it then asks for its URL. My apologies for the handholding exercise, but I use a computer regularly and see no direct upload.
From another source, this is the type of situation referred to in my OP. Please reread for clarity. https://i.ytimg.com/vi/Mrr3wIFjxqI/hqdefault.jpg
The amp I have in mind is definitely push-pull output. A hi-fi unit with one channel to be connected across each of the + and - terminations as shown on the diagram linked above.
I am. at this moment, looking at the Upload button on my browser. It is near the bottom of this message window and to the right of the Post Reply and Preview buttons. It will give you a file selection window etc. etc. follow the instructions it gives you.
I have great sympathy. Whenever I ask supermarket staff where an item can be found, I always find I am standing right next to it. Sheepish grin :smile:
If I could upload a screenshot, it would show there is nothing to the right of the post reply button. It's on the very edge of the content box. No "preview" button either. At a loss to explain, but then I use Linux.
Can anyone offer a reply to my original question?
Hmm. now the buttons have appeared in the "Have something to add?" field. IOW I needed to reply to myself (apparently).
So here is the diagram I made to clarify my original question.
This seems to me to be a question involving Inductance. Your arrangement has two loops in the opposite sense so the Inductance will be (ideally) zero for the reason you suggest. So called Bifilar windings are used when the parasitic (unwanted) Inductance needs to be eliminated or reduced. It works as long as the dimensions of the coil are a lot less than the wavelength of the signal.
PS Could the missing buttons have been caused by 'Zoom"? What actual browser are you using? Firefox works on most Operating Systems, I think.
If you drive the two wires in differential mode, then yes, you will get two opposite voltage peaks per AC cycle. If you drive them in common-mode, they have the same voltage throughout the AC cycle.
Can you say more about your project? We can probably help you figure out how to do what you want to do if we know more context. Thanks. :smile:
12K
11K
  • · Replies 28 ·
46K
  • · Replies 30 ·
