Why does a higher absorption coefficient result in a smaller emissivity value?
  • Context: Graduate
  • Thread starter Thread starter Carlos de Meo
    Emissivity Reflection
The discussion revolves around the relationship between absorption coefficients and emissivity values in materials, particularly in the context of thermal properties. Participants explore theoretical frameworks, equations, and examples related to this topic.
  • One participant notes that a good emitter must also be a good absorber, referencing the relationship between absorption and emission, and questions why higher absorption coefficients (K values) lead to lower emissivity (ε).
  • Another participant suggests that metals, which are good reflectors due to high K values, tend to have low emissivity, indicating a potential contradiction in the initial assumption.
  • A different participant clarifies that absorption is proportional to the product of emissivity and the absorption coefficient (εk), rather than k alone.
  • One participant questions the applicability of the equations presented, specifically regarding the assumptions of a perfectly smooth interface and the definition of absorptivity (β).
  • Another participant corrects their earlier statement, indicating that absorption is related to the imaginary part of the relative dielectric constant and discusses exceptions in metals like gold and copper, which absorb light in specific regions of the spectrum.
  • Further contributions highlight that reflections at the interface between dielectrics are specular and that computed emissivities are estimates, noting the complexity of real-world interactions such as diffuse reflection and wavelength dependence.
Participants express differing views on the relationship between absorption and emissivity, with no consensus reached. Some argue for the traditional view of good absorbers being good emitters, while others present counterexamples, particularly in the case of metals.
Participants note limitations in the equations used, including assumptions about interfaces and the nature of reflection, which may not hold in all scenarios. The discussion also acknowledges the complexity of calculating emissivity accurately due to various factors affecting reflection and absorption.
Carlos de Meo
Hi Guys
Im studying some thermal properties for my masters and while reading an article a weird thing happened:
As far as i know, a good emitter must be a good absorber (since emission happens "after" absorption")
Combining Fresnel equation for a medium that absorbs radiation and Kirchoff law
ρ= (n1-n2)2+k2/((n1+n2)+k2)
and 1-ε=ρ (at equilibrium)
We find that
ε= 4n/((n+1)+k2) assuming that medium 1 has n=1
So, in the end i was asking myself, the more medium 2 absorbs (higher K values), smaller the value of ε is. But, higher absoption should increase emissivity
Can anyone help me to explain this phenomena
ps: sorry for bad english, I am brazilian
ps2: ε stands for emissivity, ρ for reflection and K, for absorption
Materials such as metals are good reflectors and they also quickly attenuate any light/electromagnetic waves that get into their interior. I believe it is their large "k" value that makes them good reflectors. And yes, the metals have low emissivity. I think in general, materials that are good absorbers that have high emissivity are not characterized as being dielectrics, which is what the equations that you are working with assume. ...editing... and what I think is a typo: Your terms in the denominator should be squared: ## (n_1+n_2)^2 ## and ## (n+1)^2 ## . Also, the numerator in the first line for ## \rho ## needs a parenthesis: It should read ## \rho=((n_1-n_2)^2+k^2)/((n_1+n_2)^2+k^2) ##.
Absorption is proportional to ##\epsilon k##, not k alone.
But the first equation i presented, isn´t it for a perfectly smooth interface between a dieletric and a second medium that can absorb radiation?
And also, isn´t absorvity β = 4πK/λ assuming there is no scattering event
Sorry, my reply wasn't correct. I wanted to say that absorption is proportional to the imaginary part of the relative dielectric constant ##\epsilon_r##. But ##\epsilon_r=(n+ik)^2##, so the imaginary part of ##\epsilon_r## is 2nk. As Charles Link already mentioned, metals are an example of materials with high coefficient of extinction k but low absorbance. A normal metal can't absorb much of the incident light because it reflects most of it. A peculiar exception are gold and copper. These two metals absorb light somewhere in the green region of the spectrum and this has the effect that reflectivity is lower for these wavelength, which gives these metals their specific colour.
Just an additional item or two. At the interface between two dielectrics, the reflections are specular, i.e. angle of incidence=angle of reflection. The equations for reflectivity above are for normal incidence (perpendicular to the surface). The specular reflectivity will vary as a function of incident angle and polarization (and is likely to vary with wavelength). Any emissivities that you compute by using ## \mathcal{E}=1-\rho ## are simply estimates. Many solids are opaque and much of the reflection is of a diffuse nature. A surface scattering and absorption takes place, and the substance typically has a biderectional reflectivity function that is even more detailed than the specular case above and is also a function of wavelength. Again any emissivities that get computed from the reflectivity are normally estimates. Perhaps there is a complex mathematical method that would give the emissivity from the spectral bidrectional reflectivity, but it would be a very complex calculation.
