Energies of a Quantum Harmonic Oscillator
The discussion centers on the energy levels of a quantum harmonic oscillator, specifically addressing the ground state energy calculated using the formula E = 0.5*hbar*ω(n+0.5). The energy for the ground state (n=0) is definitively 0.5*hbar*ω, with a probability of 100%. The formula applies specifically to quantum harmonic oscillators, and when dealing with non-eigenstate initial wave functions, one must utilize Fourier analysis to express the state as a linear combination of eigenstates.
  • Understanding of quantum mechanics principles
  • Familiarity with harmonic oscillators in quantum systems
  • Knowledge of eigenstates and eigenvalues
  • Basic skills in Fourier analysis
  • Study the derivation of the quantum harmonic oscillator energy levels
  • Learn about Fourier transforms in quantum mechanics
  • Explore the concept of eigenstates and their significance in quantum systems
  • Investigate time-dependent wave functions in quantum mechanics
Students of quantum mechanics, physicists studying quantum systems, and anyone interested in the mathematical foundations of quantum harmonic oscillators.
Kyle91
Hey guys
I was just looking over a past homework problem and found something I'm not too sure on -
A particle is in the ground state of a Harmonic potential V (x) = 0.5mω2x2
If you measured the energy, what are the possible results, and with what
probabilities?
Now I know the answer to this is 0.5*hbar*ω and 100%. But I'm just a bit confused about when the formula for calculating this energy value can be applied.
When can we use that? ^ Is it just for quantum harmonic oscillators or is it for all Quantum systems?
Cheers
If the state of the particle is the nth eigenstate, then you can use that last formula. When it is in the ground state, it still holds with n=0. When you are given some initial wave function that is not one of the eigenstates, you need to calculate the c values with fourier's trick, and then express the initial state as a linear combination of the eigenstates. Then the time dependent wave function is gotten by attaching the standard time dependence to each piece of the summation.
  • · Replies 16 ·
