Calculating the Wavelength of Monochromatic Radiation in Compton Scattering
Compton scattering is utilized to measure photon direction and energy, with a specific experiment revealing a maximum electron energy of 150 keV. The wavelength of incoming monochromatic radiation can be calculated using the Compton formula and energy conservation principles. The correct approach involves recognizing that the maximum energy transfer occurs when the scattering angle is 180 degrees, leading to a specific calculation of the wavelength. The proposed method of equating total energy to the maximum electron energy is flawed, as it misinterprets the relationship between photon energy and the kinetic energy of the scattered electron. Understanding the distinction between total energy and kinetic energy is crucial for accurate wavelength determination.
Pouyan
Compton scattering can be used both to measure the direction and energy of photons in nuclear physics experiments. For a particular preparation a spectrum of Compton scattered electrons was measured which clearly corresponded to a generally monochromatic gamma radiation. The maximum electron energy was measured to 150 keV. Calculate the wavelength of the incoming monochromatic radiation.
What do I know :
Compton formula : λ'-λ = (h/mc) * (1-cos(θ))
Energy conservation: hc/λ + m * c^2 = hc/λ' +γ*m *c^2
E_befor = hc/λ , E_after = hc/λ'
The correct solution is :
E_max = 150 keV = 2.4 * 10-14
λ'-λ = (h/mc) * (1-cos(θ)) and maximum occurs when cosθ = -1 then :
λ'-λ = 2*(h/mc)
Further we have :
E_befor + m * c2 = E_after + γ*m *c2
E_befor - E_after = (γ-1)mc2 = E_kinetic
E_kinetic = hc((1/λ)-(1/λ')) †
We take E_kinetic = 150 keV = 2.4 * 10-14
and solve λ'= 2*(h/mc) + λ
and just put everything in † and solve λ which is = 0.044nm
My question is why can't we solve this by thinking :
hc/λ + m * c^2 = hc/λ' +γ*m *c^2 = Constant = 2.4 * 10-14 J
and just take hc/λ + m * c^2 = 2.4 * 10-14 J ? I don't get the same λ as the solution and I know it's wrong but why is this wrong?!
Why would the maximum electron energy be equal to the total energy of the photon-electron system? That's what you're claiming in your method.
10K
