Energy conservation( system of masses)
The problem involves a system of three connected masses (m1, m2, m3) where m2 rests on a table with a given coefficient of friction. The system is released from rest, and the objective is to determine the velocity of m3 after it has fallen a specified distance. The original poster emphasizes the need to use the energy conservation method for the solution.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of energy conservation principles, including the work done by friction and the potential and kinetic energy changes in the system. There are attempts to set up equations for each mass and to account for the work done against friction.
Some participants have provided guidance on how to approach the problem by considering the entire system rather than isolating individual masses. There is ongoing exploration of the equations and the implications of friction on the energy balance, with participants expressing uncertainty about their calculations and seeking verification of their results.
Participants note the importance of correctly accounting for the work done by friction and the need to maintain consistent units and signs in their equations. There is also mention of the initial conditions and the requirement to consider the entire system's dynamics.
murcy
Problem and Data
three masses conected m1= 800g, m2 =1100g m3=1200g. m2 rest on a table of coefficient μ=0.345. m1 and m3 hang vertically over frictionless/massless pulleys. The system is released from rest. Whats the velocity of m3 after falling 60.0cm
P.S "i know this system can be solve with finding tension and such, but i have to use energy conservation method."
W(work)= ΔK+ΔUg(potential gravitational)+ΔUs(Spring energy)
The velocity for m3 would be the same for all three masses because they are connected by a string. There's no k (initial) and spring energy involved.
This is what i have gotten so far;
I made a system of equations for each body:
Δy i defined as the change of height for potential energy.
m1;
W= (1/2)m1v^2+ m1gΔy
m2;
W= (1/2)m2v^2
m3;
W=(1/2)m3v^2-m3gΔy (the minus from negative displacement in height(Δy))
Im not sure about the following, i think I am missing something;
*I also know that the system is losing energy by the interaction of M2 w/ the surface of the table...friction.
so friction(f)= N(normal)*μ(K).
In other words: f=m2*g*μ
and Work is also =f*r(displacement by the force)* cos (θ)
θ being the angle between the force and the displacement."
I'm just not sure how to related the energy lost W on all three bodies
Thanks for any input or help you guys can provide on my problem.
I think you have 3 masses total, M1, M2, and M3 (you shouldn't change from lower to upper case letters).
Each has the same velocity and each move the same distance.
The equation you have written for Work is for work done by non conservative forces (the work done by friction on M2 in this case). That's the part that goes on the left side of the equation. The change in KE and the change in PE go on the right side, as you have indicated in your relevant equation. Watch signage, and please show your work in arriving at a solution. And welcome to PF!
Hi and thanks :),
sorry about the upper case M.(changed).ok so the work on m2 would be;
w= (1/2)m2v^2
frcosθ= (1/2)m2v^2
N*μ(-1)=(1/2)m2v^2
-mg*μ=(1/2)m2v^2
-(1.1kg)(9.8m/s^2)*(0.345)=(1/2)(1.1kg)v^2
solve for V;
-3.719N=0.55kg v^2
v^2=-3.719N/0.55kg
v^2=-6.762m^2/s^2
v=sqrt(-6.762 m^2/s^2)...i know I am wrong here since ill have a neg inside a sqrt :(, but if somehow the inside is pos ill have v= 2.60m/s...
im sure this is not right :/
I'm sorry but I am still stuck in this problem :/
You can't just isolate one block to determine its speed unless you include the work by the tension forces as well. Instead, look at the entire system of three blocks. Use your original equation, which is
[itex]W_{friction} = (KE_{final} - KE _{initial}) + (PE_{final} - PE _{initial})[/itex], where the initial and final KE's and PE's of each block must be determined and included in this equation.
Thanks for the reply Jay;
I understand what you mean now, this is what i have so far i hope is right;
Wfriction= (1/2)(m1+m2+m3)v^2+(m1-m3)gΔy
Wfriction=(1/2)(0.8kg+1.1kg+1.2kg)v^2+(0.8kg-1.2kg)(9.8m/s^2)(0.6m)
Wfriction=1.55kg*v^2-2.352joules
earlier i found;
Wfriction=fdcosθ and f=μk*N(m2g)
Wfriction=0.345*1.1kg*9.8m/s^2*0.6m*-1
Wfriction=-2.23 joules
so;
-2.23j=1.55kg*v^2-2.352j
i ended up with v= sqrt(0.07871m^2/s^2)
v=0.2806m/s i wish i could verify this answer but looks reasonable
earlier i found;
so;
yes
Yeah, looks OK!
Thanks a bunch Jay~
10K
