Energy dissipated in 3-cars collision
  • Thread starter Thread starter geoffrey159
    Collision Energy
The problem involves a collision scenario with three cars, where two cars are initially at rest and one car collides with them. The focus is on determining the fraction of initial energy dissipated during the collisions, which are described as completely inelastic.
  • Participants discuss the conservation of momentum and energy dissipation in inelastic collisions. The original poster attempts to calculate energy loss for each collision and presents a total energy loss. Others suggest exploring simpler methods and recursive approaches for multiple cars.
Some participants have provided feedback on the original poster's calculations, indicating that the approach is valid but may be simplified. A recursive method for handling multiple cars has been introduced, suggesting a productive direction in the discussion.
Participants are considering the implications of varying numbers of cars in the collision and the potential for different mass configurations, which may influence the energy calculations.
geoffrey159
Cars B and C are at rest with their brakes off. Car A plows into B at high speed, pushing B into C. If the collisions are completely inelastic, what fraction of the initial energy is dissipated when car
C is struck? The cars are identical initially.
Collisions
First collision:
Momentum is conserved and the collision is inelastic so ##mv_1 = 2mv_2##. The energy dissipated after the first collision
is ## Q_1 = \triangle K = \frac{1}{2} mv_1 ^2 - m v_2^2 = \frac{1}{4}mv_1^2 = \frac{1}{2} K_i ##
Second collision:
Momentum is conserved and the collision is inelastic so ##2mv_2 = 3mv_3##. The energy dissipated after the second collision is ## Q_2 = \triangle K = m v_2 ^2 - \frac{3}{2}m v_3^2 = \frac{1}{3}mv_2^2 = \frac{1}{12}mv_1^2 = \frac{1}{6} K_i ##
Total energy lost is ## Q = Q_1 + Q_2 = \frac{2}{3} K_i ## so the fraction of initial energy dissipated after C is struck is 2/3.
Is that correct?
Looks good. Anything else?
Thank you ! What do you mean by 'anything else ?' ?
You've not done anything wrong but can you see a simpler way? What if there were 10 cars?
Yes, there is a recursive way to do it:
With momentum conservation and inelasticity: ## mnv_n = m(n+1) v_{n+1} ##
So ## v_n =\frac{v_1}{n} ## and total energy lost for n-car collision is ## Q = K_i - K_n = (1 - \frac{1}{n}) K_i ##
Yes, you need only consider energy and momentum at the beginning and end. Even if the cars were different masses.
I see, it would have been simpler to consider the general case ! Thanks !
  • · Replies 29 ·
  • · Replies 28 ·
  • · Replies 20 ·
