Undergrad Energy needed to launch a spaceship into Space
The discussion centers on calculating the energy required to launch a spaceship with a mass of 4000 kg to a height of 100 km above a planet with a mass of 6.42*10^23 kg and a radius of 3.39*10^6 m. The gravitational constant is given as G = 6.67*10^-11. The spaceship is assumed to have zero velocity upon reaching the height of 100 km. Participants suggest calculating the potential energy needed for this ascent and clarify the importance of showing work in homework-related queries. The thread concludes with a reminder to post in the appropriate forum for schoolwork assistance.
IsakVern
A given planet has a mass, M = 6.42*10^23 kg,
and radius, R = 3.39 * 10^6 m.
The gravitational konstant is G = 6.67*10^-11
A spaceship with mass m = 4000 kg is launched from the planets surface.
How much energy is needed to send the spaceship to a height h = 100 km above the planets surface?
Hi Isak:
There are several ways to approach this problem. One way is to calculate the potential energy of the spaceship at the height of 100 km. That is the amount of energy that has to be added to get the spaceship to that height.
First, the problem statement is a bit unclear. What is the assumed state of the spaceship when it reaches a height of 100 km. Here are two possibilities:
a) the spaceship is in orbit around the planet.
b) the spaceship has zero velocity and will begin its fall back to earth.​
Hope this helps.
Regards,
Buzz
The assumed state of the spaceship is that it has zero velocity when it reaches 100 km.
Hi Isak:
In that case I suggest you calculate the potential energy. You might find the following of some use. See the formula in the second box.
You may find the minus sign puzzling. If so, see what your textbook says about potential energy.
Regards,
Buzz
Thread is locked.
@IsakVern -- All schoolwork problems go in the Homework Help forums, and you are required to show your work before we can offer tutorial help. Please re-post in the Homework Help, Introductory Physics forum, and fill out the Homework Help Template you are provided there. This includes sections on the Relevant Equations and your Attempt at a Solution.
@Buzz Bloom -- Please do not reply to misplaced schoolwork questions, especially when the OP shows zero effort in their post. Please click the Report link on their post instead, and ask the Mentors to deal with the post. Thanks.
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 16 ·
  • · Replies 20 ·
