Energy problem (compression of a spring)
  • Thread starter Thread starter Wellenbrecher
    Energy Spring
The problem involves a 4.29-kg ball of clay thrown downward onto a spring, with the goal of determining the maximum compression of the spring and the total work done during this compression. The context includes concepts from energy conservation, specifically gravitational potential energy, kinetic energy, and elastic potential energy.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of energy conservation equations, questioning the setup and assumptions made in the calculations. There are attempts to clarify the correct use of gravitational potential energy and elastic potential energy in the context of the problem.
Some participants have provided guidance on how to approach the equations and have suggested checking for arithmetic or algebraic mistakes. There is acknowledgment of the need for significant figure consistency in the results. The discussion has led to a confirmed answer for the maximum compression of the spring, but there remains an inquiry about the work done during compression.
Participants note the importance of significant figures in the calculations and the potential for errors in unit conversions or signs. There is an ongoing exploration of the equations used for calculating the total work done on the clay.
Wellenbrecher
A 4.29-kg ball of clay is thrown downward from a height of 2.53 m with a speed of 4.21 m/s onto a spring with k = 1770 N/m. The clay compresses the spring a certain maximum amount before momentarily stopping.
a) Find the maximum compression of the spring.
b) Find the total work done on the clay during the spring's compression.
Ep = mgh
Ek = 1/2mv2
Espring = 1/2kx2 (k: spring constant, x: compression length)
I tried two equations but I couldn't find the true answer.
First equation I solved is
mgh + 1/2mv2 = 1/2kx2
And the second one is
mg(h+x) + 1/2mv2 = 1/2kx2
3. Extra Info
Following answers are FALSE for question a:
0,1234982833 m
0,49698749 m
0,40406548 m
Following answers are FALSE for question b:
271,740459713 J
144,4929915 J
-162,5281058 J
Can you show some additional details about how you calculated your attempts? We need to see how you are applying the Relevant Equations.
Also, 10 digits of accuracy is a bit much when the given values have three significant figures. You might want to round your results to match the given number of significant figures.
Hi there!
It would have been clearer and easier for us to help you if you indicated what numerical answers you got using which equation, rather than just putting the numbers out there.
Anyway, I think you have the equations right. Just equate the energy of the clay at the top ( ## E = KE + U_{grav} ## ) and the energy at the bottom (## E = U_{elastic} ##). The second equation you identified in your attempt is correct, because you set ## U_g = 0 ## at the point of maximum compression of the spring.
Are you sure your answer is wrong? Maybe you only made a mistake with the units or sign (negative or positive) somewhere?
Hmm. I believe your formulas are correct. The difference between mgh and mg(h+x) is only whether you take into account the extra distance the mass falls as it compresses the spring. I don't think for this problem there will be much difference in the final answers.
I think you may have just made an arithmetic or algebraic mistake, or else used the wrong value for one of the constants. Could you write out your answer symbolically, giving x in terms of m, g, h and v?
For mgh + 1/2mv2 = 1/2kx2
4,29*9,81*2,53 + 1/2*4,29*4,212 = 1/2*1770*x2
144,4929915 = 885*x2
x2 = 144,4929915/885
x2 = 0,1632689169491525423728813559322
x = 0,40406548596626332293541051481052 m
System doesn't accept this answer.
For mg(h+x) + 1/2mv2 = 1/2kx2
4,29*9,81*(2,53+x) + 1/2*4,29*4,212 = 1/2*1770*x2
42,0849*(2,53+x) + 38,0181945 = 885*x2
42,0849*x + 144,4929915 = 885*x2
885*x2 - 42,0849*x - 144,4929915 = 0
x0 = -0.380988 x1 = 0,428541 m
I haven't found 0,428541 m before. Can someone check my solution and look for arithmetic mistakes? Since I've used 3 out of 4 tries, I can't dare to post it to the system. If you confirm this answer, I will post it.
And please teach me how to solve the question b. Is the equation for it "-(mg(h+x) + 1/2mv2) J" ?
I don't know what your x0 and x1 are, but the number is near enough right. (I get 0,42836...)
You are only given data to three significant figures, so you should not have more significant figures in your answer. It implies too great a degree of accuracy.
Wellenbrecher said:
please teach me how to solve the question b. Is the equation for it "-(mg(h+x) + 1/2mv2)J"?
Yes.
System accepted 0,42854 m for question a. Thanks everyone :)
  • · Replies 17 ·
