Energy released through alpha decay
16 replies · 4K views
songoku
The radioactive isotope radon-222 may decay spontaneously by emitting an alpha particle. The daughter nucleus is an isotope of polonium. The atomic masses of these isotopes are:
Rn-222 : 222.0157 u
Po : 218.00896 u
He : 4.00260 u
A sample of radon-222 contains 3.0 x 107 nuclei. The total energy that will be release in a time interval of 3 T1/2 through alpha decay of the radon-222 is:
a. 3.856 MeV
b. 5.785 x 107 MeV
c. 8.677 x 107 MeV
d. 1.012 x 108 MeV
e. 1.085 x 108 MeV
E = mc^2
T1/2 = (ln 2) / λ
If the question asks only for one half-life then the energy released = (mass of Rn - mass of Po - mass of He) x 931.5 MeV. Is this correct?
I don't know how the time interval of 3 half-life and number of nuclei play part in this question. Are they used to find energy released or they are only redundant information?
Thanks
Rn-222 : 222.0157 u
Po : 218.00896 u
He : 4.00260 u
a. 3.856 MeV
b. 5.785 x 107 MeV
c. 8.677 x 107 MeV
d. 1.012 x 108 MeV
e. 1.085 x 108 MeV
E = mc^2
T1/2 = (ln 2) / λ
Thanks
What happens during a half life?
Radon decays so the number of nuclei becomes half of original. The mass will also becomes 111.00785 u? The mass of He will stay the same as before?
How about mass of Po?
Thanks
Thanks
In one half life half of the original nuclei decay. So, what about after three half lives.
The atomic masses of the isotopes don't change!
The nuclei of radon will be 3/8 × 107
You mean the mass of radon will still be 222.0157 u? Does decay also change the mass of the nuclei?
Thanks
songoku said:
The nuclei of radon will be 3/8 × 107You mean the mass of radon will still be 222.0157 u? Does decay also change the mass of the nuclei?
Thanks
I would have said: after three half lives 7/8 of the original nuclei will have decayed.
The Radon nuclei are decaying into different nuclei, so the original nuclei are either gone or still the same.
That doesn't seem like a particularly difficult concept!
So the number of nuclei, mass, activity will be 1/8 of original?
One simple basic question:
radon decays into Po by emitting alpha. Let say the number of nuclei of radon is x initially. After 1 half life, the number of nuclei of radon is 1/2 x and Po is 1/2 x. After 2 half life, radon is 1/4 x and Po is 3/4 x. Is this correct?
The particle "lost" by radon becomes Po? Alpha particle not taking some of particle "lost" by radon?
Thanks
Yes.
I do not understand your terminology. The number of particles of radon lost equals the number of particles of Po created and equals the number of He particles created (ignoring the decay of Po).
I am not sure I get what you mean. If the particles lost by radon = Po + He created, does it mean after two half life, radon will be 1/4 x but Po is not 3/4 x (Po will be y and He will be z where y + z = 3/4 x)?
No. Radon decays into Polonium plus Helium.
You can see by the atomic masses than one Polonium plus one Helium almost adds up to one Radon.
PeroK said:
Radon decays into Polonium plus Helium plus an alpha particle.
No, the Helium nucleus is the alpha particle - same thing.
No, I mean that each decaying Radon becomes one Po plus one He, the He being the alpha particle.
PeroK said:
No. Radon decays into Polonium plus Helium plus an alpha particle.
After 1 half life:
Radon = 3/2 × 107 nuclei
Mass of remaining radon = 3/2 × 107 x 222 x 10-3 / (6.02 x 1023) = 5.53 x 10-18 kg
Po = 3/2 × 107 nuclei
Mass of Po = 3/2 × 107 x 218 x 10-3 / (6.02 x 1023) = 5.43 x 10-18 kg
Mass of He = 4 x 1.66 x 10-27 = 6.68 x 10-27 kg
Energy released = (5.43 x 10-18 + 6.68 x 10-27 - 5.53 x 10-18) x (3 x 108)2 = 9 x 10-3 J = 5.625 x 1010 MeV
and it is wrong...:confused:
songoku said:
After 1 half life:
The question specifies 3 half lives. Also, why use kilograms and Joules? That's just making the calculations much more complicated.
Also, surely it's much simpler to calculate how much energy (in ##u## and ##MeV##) is released by one decaying Radon. Then work out how many Radon nuclei decay and multiply the two together.
I mean my calculation for just 1 half life already wrong, not to mention it still needed to be added with 2 and 3 half life.
Just habit to use SI unit
Energy released by one decaying Radon = (218.00896 u + 4.00260 u - 222.0157 u) x 931.5 MeV = 3.86 MeV
After three half lives 7/8 of the Radon will have decayed, so total energy released = 3.86 MeV x 7/8 x 3 x 107 = 1.013 x 108 MeV
Is this correct?
If the question asks for only 1 half life, instead of 7/8 I should use 1/2?
Thanks
Is this correct?
Yes.
Yes.
Thank you very much for the help Perok and haruspex
