Energy Spectrum of Two-State System
8 replies · 3K views
atomicpedals
A two-state system has Hamiltonian
[itex]\sum |i\right\rangle h<sub>i</sub> \left\langle i| + Δ (| 1 \right\rangle \left\langle 2| + |2 \right\rangle \left\langle 1 |)[/itex]
Where, [itex]\left\langle i | j \right\rangle = \delta<sub>ij</sub>[/itex], [itex]h<sub>i</sub>[/itex], and Δ are real.
Compute the energy spectrum of this Hamiltonian.
N/A
What is this question asking me to do? What is meant by "energy spectrum"?
Also; tried cleaning up the tex but something's not right and I can't seem to tell what (other than I'm on a different computer than I normally use).
[itex]\sum | i \rangle h_i \langle i | + \Delta (| 1 \rangle \langle 2 | + | 2 \rangle \langle 1 |)[/itex]
Where, [itex]\langle i | j \rangle = \delta_{ij}[/itex], [itex]h_i[/itex], and Δ are real.
N/A
The problem wants you to find all possible results if you measure the energy of the system.
Ok, my hamiltonian here is an hermitian operator plus a laplacian. This also tells me that |1> and <2| are vectors ([1,0] and [0,1] I think). As a painfully basic question of working with bras and kets, what is the operation (if that's the right word) |1><2| telling me to do?
Δ is just a number, not the Laplacian.
Try calculating the matrix that represents the Hamiltonian in the [itex]\vert 1 \rangle[/itex] and [itex]\vert 2 \rangle[/itex] basis.
Ah, ok, Δ being a number makes life a bit easier (I've just gotten use to it being a Laplacian every other time the prof uses it).
I'm probably getting held up on notation (that I don't know what |1><2| means); and I'm not totally sure what you mean by calculating the matrix that represents the Hamiltonian in the [itex]\vert 1 \rangle[/itex] and [itex]\vert 2 \rangle[/itex] basis. Should this result in a diagonalized matrix?
You really need to go back and learn the basics of how operators and matrices are related. What I'm telling you to do is find the matrix
\begin{bmatrix}
\langle 1 | \hat{H} | 1 \rangle & \langle 1 | \hat{H} | 2 \rangle \\
\langle 2 | \hat{H} | 1 \rangle & \langle 2 | \hat{H} | 2 \rangle
\end{bmatrix}
Surely your textbook goes over Dirac notation.
I am, and it does (we're using both Merzbacher and Griffiths, leaves me in a bit of an information over load).
Let [itex]\hat{A} = \lvert a \rangle\langle b \rvert[/itex]. Say you want to calculate [itex]\langle \psi \lvert \hat{A} \rvert \phi \rangle[/itex]. You have
[tex]\langle \psi \lvert \hat{A} \rvert \phi \rangle = \langle \psi \lvert (\lvert a \rangle\langle b \rvert) \rvert \phi \rangle[/tex]It works just like the notation suggests:
[tex]\langle \psi \lvert \hat{A} \rvert \phi \rangle = \langle \psi \lvert \lvert a \rangle\langle b \rvert \rvert \phi \rangle = \langle \psi \vert a \rangle \langle b \vert \phi \rangle[/tex]
