Bulb Energy Transfer: How Does Voltage Affect Filament Breakage?
The discussion focuses on the operation of a 120 V, 40 W electric bulb and its behavior when connected to a 240 V supply. The current in the bulb is calculated using the formula P = IV, resulting in 0.33 A at 120 V and 0.66 A at 240 V. Energy transfer from the filament occurs through conduction, convection, and radiation, with an emphasis on how these mechanisms change with increased voltage. The bulb can operate for an hour at 240 V before filament breakage due to the relatively small increase in current, which affects the heat emitted compared to light.
  • Understanding of electrical power calculations (P = IV)
  • Knowledge of energy transfer mechanisms: conduction, convection, and radiation
  • Familiarity with the concept of filament temperature and black body emission
  • Basic principles of electrical circuits and voltage ratings
  • Research the relationship between voltage and current in resistive circuits using Ohm's Law
  • Explore the principles of black body radiation and its dependence on temperature
  • Investigate the effects of increased voltage on filament materials and their thermal properties
  • Learn about the thermal management of light bulbs and how to optimize energy efficiency
Students studying electrical engineering, physics enthusiasts, and anyone interested in the principles of energy transfer in electrical devices.
Kushal
An electric bulb is marked 120 V, 40 W.
(a) Calculate the current in this bulb when operating on a 120 V supply.
(b) Describe 3 different ways in which energy can be transferred from the filament when it is operating normally.
(c) If the light bulb is now connected to a 240 V supply it will work for perhaps an hour as a 160 W bulb before its filament breaks.
(i) How will the relative importance of the answers you have given to (b) change when the bulb is run on this increased voltage?
(ii) Suggest a reason why this bulb can operate for so long a time before its filament breaks.
(a) i calculated the current using P = IV
(b) the different ways are : conduction, convection and radiation.
(c)(i) I can't understand what the question asks
(ii) I am thinking that maybe it's because the increase in current is small. the current flowing increases from 0.33A to 0.66A
c) is asking how the importance of each conduction, convection and radiation, change when the bulbs voltage increases. For example, perhaps it will begin to emit more energy as heat rather than light?
ah well, i suppose the heat transferred by all of these ways will increase because the current increases?! is it right?
Have you learned anything about the black body emission, and how it depends on temperature?
errmm no. I'm going to google that. thanks
9K
  • · Replies 19 ·
  • · Replies 16 ·
