Engine design -- Fusion powered rockets
16 replies · 4K views · last reply
Xforce
I found this interesting engine design on the internet. It is one of the most powerful and largest machines human have ever designed. It is a fusion powered propulsion device, it uses “heavy fusion technology” which can use any elements lighter than Fe-56 as power source. Is this design feasible?
Black and white cutaway technical drawing of a large vertical engine or reactor assembly, with a dome-shaped top, a narrow central section and a wide base with many internal components.
  • Black and white cutaway technical drawing of a large vertical engine or reactor assembly, with a dome-shaped top, a narrow central section and a wide base with many internal components.
No, not at this time since we can't even get fusion power to work yet.
IIRC, nearest we've got to a practicable fusion powered rocket is the BIS Daedalus design, but that approach foundered on the difficulties of pulsed 'laser ignition'. Seems that's as hard to 'break even' as Tokamak, Stellerator etc configurations...
( I'm not current on the Polywell design, but I lost interest when that ran into apparently intractable scaling issues... )
Grayscale rendering of a symmetrical, intricately detailed spacecraft thruster or engine nozzle viewed head-on, with lattice-like arched structures and ornate machinery against a cloudy sky.
This is another view of that thruster...
  • Grayscale rendering of a symmetrical, intricately detailed spacecraft thruster or engine nozzle viewed head-on, with lattice-like arched structures and ornate machinery against a cloudy sky.
You should just put it into the right novel and it'll do miracles.
But in real life, no.
The source of this image is google image. Same thing as this concept graph.
Digital concept art of a massive frozen, ice-covered spacecraft with a glowing blue beam of light above its dome, a lone figure standing on icy ground and a wrecked vessel in the foreground.
  • Digital concept art of a massive frozen, ice-covered spacecraft with a glowing blue beam of light above its dome, a lone figure standing on icy ground and a wrecked vessel in the foreground.
You're asking an Engineering Question here. No amount of Artist's Impressions will constitute evidence of the practicability of anything.
The sort of images that you have supplied are presented in countless sales pitches for countless schemes for doing all sorts of things. They can sometimes convince people to part with their money. . . . . . . . . . .
Please make it a habit to post a link to any images that you post at the PF (or at any online discussion forum). It is generally a copyright violation to post images without attribution. Thank you.
That’s not a technical design, that’s art. It might be good, detailed art but it’s no more feasible than a Star Wars technical manual showing you the insides of an X-wing. It’s completely made up for entertainment.
Ok, I just want to show the size and the exhaust of that engine. The bluish color suggests that the temperature of the plasma beam is more than 40000 degrees kelvin, something like a blue giant star’s surface. Materials will melt down unless there is a magnetic nozzle, and there is one in design. From the huge size and advanced fusion technology, we know that this thing is impossible in the near future. But once we can construct this type of thruster, it will readily propel the largest starships and given enough numbers ang enough time, propel planets:)
I am not advertising anything, I just want to discuss if the scientific principles of this thing works in reality, that is why it is in the sci-fi area. But I only see people repelling this idea.
Not so much "repelling" or rejecting, just providing a reality check. And from your 2nd post above that I quoted, it seems like you understand that it's a (long) ways off. That's all.
From a 'hard' science fiction approach it is difficult to understand a need for such a large device. If you are moving a large asteroid or space habitat, slow and steady makes sense such as a continuous ion drive. A fusion device as suggested in the art work would likely pollute the environment and cause massive radiation problems during deceleration when the star ship or habitat essentially 'follows' the drive exhaust.
Two drive suggestions from published 'scientific' SF:
1) Fusion drives including Bussard ramjets and gravtity control appear in many Larry Niven novels such as "Protector" and the Ringworld series. Niven describes design, operation and dangers associated with fusion drives in "Protector" including long term maintenance.
2) Glen Cook presents a very economical 'hyper drive' powered by matter (hydrogen) / antimatter annihilation in the combat SF novel "Passage at Arms". Climbers resemble your OP picture but at a reasonable size limit of 9,000 tons. The author imposes strict size limits for climbers because they enter another dimension, analogous to submarines using another dimension than surface vessels. Larger craft utilize fusion drives as does a climber before it is fueled with antimatter. See this synopsis if interested https://matthilliard.wordpress.com/?s=passage+at+arms
Hmmm, not sure about that.
Basically, the "heavy fusion" aspect (and I'm acknowledging that this conversation is off an artists diagram so won't get too fussy about the detail) may not be a practical design feature. We know of two basic types of fusion reactions: those that preserve the number of protons and neutrons, and those that involve a conversion between protons and neutrons. The first type is the focus of our fusion-energy projects (ITER for example) and is commonly referred to as the D-T fusion reaction, while the second starts stars burning and is commonly referred to as the H-H fusion reaction. We focus on the D-T in energy generation because the net energy release from the D-T reaction is forty times greater than the H-H reaction. (Which is not to suggest that H-H is "energy poor." Both reactions liberate a lot of energy, esp. compared to how we normally generate the stuff!)
But the trouble with the "heavy fusion technology" aspect is that not all elements fuse usefully. Wikipedia has a very detailed - and physics heavy - overview of this at https://en.wikipedia.org/wiki/Nuclear_fusion#Important_reactions, but essentially, only a few light elements (hydrogen, helium, and boron just barely) make the grade as practical fusion fuels. So expecting to top up the tanks with oxygen or carbon and fuse it up to power the thrusters, is very unlikely.
This isn't too surprising when you think PF is a Scientific Forum. The 'appealing' picture in your OP was not likely to be treated seriously, I'm afraid and it probably overshadowed your question about 'Heavy Fusion'.
