Engineering Design: Truss Bridge Questions
In truss bridge design, it is normal for individual members to experience internal forces greater than the external applied force, as long as they do not exceed the member's load-carrying capacity. The self-weight and dead loads of structures typically surpass live loads, complicating load distribution. Real-world structures often bear distributed loads rather than point loads, requiring special arrangements for effective load transfer. Zero force members (ZFMs) are generally unnecessary in practical applications, as they rarely experience zero force under various load conditions. Understanding these dynamics is crucial for effective truss bridge design and ensures structural integrity.
WatermelonPig
Hey.
I am currently in an engineering class designing a truss bridge and had a couple questions. (Note all truss members are considered to be two-force members)
1) Suppose the truss is symmetric and a force is applied through the middle of it. Is it normal in industry for any individual member to have an internal force greater than this external force? Would such a case be considered a design flaw?
2) How necesary is it really to remove ZFMs? (Again, in industry)
These are strange questions.
Firstly you should realize that in the real world self weight imposes a significant load on a structure. In the case of bridges, which you mention, the self weight plus the dead load is usually far greater than the live loads, which vary.
Secondly real world structures are not loaded at one point. Most carry a distributed load of some sort and special arangements are made to transfer these to joints in trussed structures. For instance for roof trusses, distributed loads such as snow loads and roof tile weights are arranged to bear on special members, known as purlins.
Particularly these days, roof trusses are made (many) of exceedingly slender floppy members to save material.
Such trusses often have redundant members for transport and assembly bracing. Further bracing is added to the roof as a whole to lock it into a stable three dimensional structure.
go well
Yes it is perfectly normal. It is only a design flaw if the internal forces are greater than the load carrying capacity of the member!
This situation doesn't really apply to "real world" structures, where there are many different load cases to be considered. For instance a truss bridge would have to withstand its own weight, loads from snow and ice, sideways loads from wind, dynamics loads from earthquakes, etc, as well as the loads from things crossing the bridge.
It is very unlikely that any member would have zero force in every load case. If it did, then you would have to find another reason why it was included in the design!
I suppose it is true that "ZFMs" actually support the weight of the other members. And that's good to know that an individual member could have such a high tension without failure. It's just a bit counterintuitive, that's all. Thank you for the replies.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
52K
