Engineing Help: Controllable Powerheads for Aquariums
  • Thread starter Thread starter gajopo
    Engineering
Controllable powerheads for aquariums are significantly more expensive than standard pumps, prompting a search for a cost-effective solution. The user is attempting to create a circuit that can supply 60Hz during the "on" state and adjustable frequencies between 1-59Hz during the "off" state to reduce pump chatter and stress on aquatic life. Current methods involve using timers and relays, but the user seeks a more efficient adjustable frequency power supply. The goal is to achieve a low wattage power supply that can maintain the pump just above its stall state. Input from knowledgeable individuals in electrical engineering is requested to aid in this project.
gajopo
The application may seem trivial, but I need to control an aquarium powerhead (pump). I'm an elevator adjuster by trade and have no problem understanding schematics and scouring datasheets but am by no means an electrical engineer.
My issue simplified, controllable powerheads cost 8-10X the cost of the same flow 120vac single speed synchronous pumps. Their ac counterparts are simple, two coils, one with a few extra turns to get the permanent magnet impeller to turn in the desired direction. Problem is with the interval timing circuit I am using the causes the pumps to "chatter" upon excitation stressing my much loved salt water inhabitants. Yes I could spend 1500$ on Tunze controllable pumps with a controller, but I like the 150$ approach better if possible.
What I would like to accomplish is a circuit that would supply 60hz during their "on" state and 1-59hz during their "off" state, slowing them to near their synchronous stall state (1-59hz, maybe 17hz??...). 60Hz is simple as I am doing that now.
How can I make a 120vac (+- 40v) 1-59Hz power supply? I have been scouring the internet for days and decided to just start posting were someone with the knowledge may see this and give me something I can plug into Electronics Workbenches MultiSim for trial and error.
For those of you who may care, a Hydor Koralia 4 (What I'm using) costs 30$. A Tunze Stream starts at 329$ plus the 12vdc controller. Both pump water, one just capitalizes on control via a large price hike.
Any input is greatly appreciated!
Gary
When you say interval timing circuit, is it just a circuit to turn them on and off at different times during the day?
Right now I am using 2 .1 to 99 second in-line timers and 2 relays. The pumps are on opposite sides of the tank set at 12 seconds, simulating the ebb and flow found in natural reefs.
Sounds like a soft starter is what you would need, can't say whether they are available for motors of that size though.
There is my problem. Single phase soft starts require specific motors with special windings, centrifugal switches, capacitors and on...
If I can find a way to make a 120vac adjustable frequency low wattage power supply I can supply on its hysteresis(off) state to slow the pump motor just above stall I will achieve my goal. At least that's my theory!
I do appreciate your interest! Keep asking.
Gary
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
