Does every natural number n being even and prime imply that there is a unique n?
  • Thread starter Thread starter cragar
    English Logic
The discussion revolves around expressing the statement "There is a unique natural number n which is both even and prime" in symbolic form without using the "there exists" symbol. Participants suggest that the solution must explicitly reference the number 2, as it is the only even prime. They explore various symbolic representations, emphasizing the need to avoid the existential quantifier. Suggestions include rephrasing the statement to indicate that not all primes are odd, which helps in constructing the desired symbolic expression. The conversation highlights the challenge of expressing uniqueness and existence without standard symbols.
cragar
Express the following English sentence as a symbolic statement.
Do not use the there exist symbol
“There is a unique natural number n which is both even and prime.”
We also have properties like
let P(n) be the property that n is prime, L(n, m) the relation that n < m, and E(n) the property that n is even.
\forall n (E(n) and P(n) and n&lt;3)
Perhaps I'm under-thinking this: 2.
It doesn't convey all the information of the original, but any sentence that does will evaluate to 2. And most will reduce to 2 as well.
What about first changing the English version into saying what is not true?
I interpret your symbolic statement (attempted solution) to mean: all natural numbers are even, prime and less than 3.
cragar said:
"There is ..."
How do you write that in symbols?
Would it work to say that n \in \mathbb{N}
n \in \mathbb{N} : (P(n) \&amp; E(n))
No, you must represent "there is" somehow. Are you not aware of a symbol for that?
the only symbol I am aware of is there exists \exists but we were told tonot use it in the problem.
Im not sure of a symbol for that
Sorry, I overlooked that.
In that case, as others have suggested, you can get around it by making explicit reference to that number. One part of your answer will express that 2 has these properties. What will the rest of your answer state?
It seems an obvious approach to me that if you're given a statement "there exists ..." and you're told not to use the ##\exists## symbol, then the first step is to rephrase the statement to avoid the phrase "there exists". That, it seems to me, is logical!
As a start, you could think of a statement like "not all primes are odd". This starts to take you in the right direction, I believe.
  • · Replies 19 ·
