Ensembles in quantum field theory
91 replies · 11K views
Insights Author
TL;DR
How does one model an ensemble of particles in quantum field theory?
A. Neumaier said:
But a fundamental description would have to come from relativistic quantum field theory, where there are no ensembles. One cannot repeatedly prepare a quantum field extending over all of spacetime.
I don't know of a single paper explaining how the transition in conceptual language from a single quantum field to an ensemble of particles can be justified from the QFT formalism. Maybe you can help me here with a reference?
vanhees71 said:
Within QFT you can as well prepare single Ag atoms as you can in QM. QFT is also used since it's conception to describe scattering cross sections, and that's also due to the standard interpretation of the quantum state in terms of Born's rule. It's explained in any QFT textbook, e.g., Weinberg, QT of Fields vol. 1.
A. Neumaier said:
One can model a single silver atom in this way. But how do you model an ensemble of 100 silver atoms moving at well separated times along a beam by quantum field theory? You cannot prepare multiple instances of a field extending over all of spacetime. The only use! of Born's rule in Weinberg's Vol. 1 (namely where he interprets the scattering amplitutes) doesn't address this issue - scattering has nothing to do with this question!
vanhees71 said:
Relativistic QFT has the same probabilistic interpretation as any QT (in fact there is only one overall conceptual framework and a non-relativistic (in both a "1st-quantization formulation" and a field-theoretical one as well as a special relativistic realization in terms of local QFTs).
Of course one can prepare ensembles within all kinds of QTs and, more importantly, in the lab. Relativistic QFT is among the best tested physical theories ever discovered. This would be impossible to achieve if it were not possible to prepare ensembles of the physical systems described by it, and these are particles and nuclei in particle accelerators, with which you can do scattering experiments with high precision. Another application is atomic physics. A specific quantum-field theoretical result is the explanation of the Lamb shift to several significant digits of accuracy, etc.
I don't understand, how one can claim that one cannot build ensembles within relativistic QFT, given all these successes. After all the first goal in all introductions to QFT is to establish the calculations of S-matrix elements, which precisely describe scattering processes, and obviously these can be realized with high accuracy in the lab.
Then please explain how the transition in conceptual language from a single quantum field (extending all over spacetime, or at least over the lab during a day) to an ensemble of particles can be justified from the QFT formalism.
I don't know, what is there to be explained. One prepares particles with an accelerator, lets them interact and detects the products. QFT predicts the corresponding cross sections. To measure these cross sections you do such scattering experiments and compare the distribution of the scattered particles for given processes.
Well, that's the few particle view. But I am asking for a more fundamental description. In a lab we perform a very simple experiment:
A source produces silver particles at an (average or equidistant) rate of one per second, which move along the z-axis towards a glass surface, adsorbing the silver atoms milliseconds after they were produced, until a faint silver spot is visible under the microscope.
The whole lab is a quantum system that can in principle (though not in practice) be modeled by quantum field theory. Thus one has a time-independent Heisenberg state for the lab, an a number of quantum fields describing the stuff in the lab during the day considered.
The silver field in some region around the beam may be considered to be a free scalar field. No scattering is involved. What is the Heisenberg state of the quantum field in this region of spacetime, given the above description?
Ensembles presumably don't have to be real. A prepared state encompassing the whole lab + quantum fields + silver field can be conceptualised as a fictitious ensemble of macroscopic systems. The extreme of this would be quantum cosmologists conceptualising an ensemble of universes.
As you write yourself, this you cannot achieve. It's simply impossible to describe the quantum state of a macroscopic object in that detail, but that's for sure not necessary to describe your scenario.
For that it's sufficient to simply describe the silver atoms alone. The initial state is the vacuum (no silver atoms present). The probability for the occurrence of the Ag atoms would be something like
$$\langle \Omega \hat{\rho}_1(t_1,\vec{x}_1) \hat{\rho}_2(t_2,\vec{x}_2) \cdots |\Omega \rangle,$$
where ##\hat{\rho}(t,\vec{x})## is the particle-density operator.
Thats why I only ask for the description of the neighborhood of the beam during the whole, very simple experiment. There the quantum field is free (ignoring air), and a detailed description is possible.
I don't want a probability, I want the Heisenberg state. If a QFT state can be assigned to systems as big as the sun through millions of years (used, e.g., to derive from it a coarse-grained hydromechanical description), one can surely be assigned to a faint silver beam in the lab through a day. (In fact I know the answer. Not every detail, but detailed enough so that one can discuss the experiment in its terms.)
How can scientific descriptions depend on fictitious stuff? Surely Nature doesn't care about our fictions...
Sure, but it doesn't mean that our fictions are independent on Nature. Our fictions care about Nature, they are chosen with intention to resemble Nature. Any human description of any phenomenon in Nature is necessarily a simplification, but the art of physics consists in finding simplifications that still keep some essential properties of Nature.
The von Neumann theory of measurement models the macroscopic measuring apparatus in a very crude way. I think you want a more detailed model, but this is not only hard in practice, but also unnecessary because it turns out that the crude models capture essential properties very well. It is a general principle in physics that properties of macroscopic systems usually don't depend much on microscopic details.
I don't understand, what you think is wrong with this standard description. All we have are probabilities. In the case you described, the state in the Heisenberg picture is the vacuum, since the state in the Heisenberg picture is time independent, and the time evolution is entirely in the field operators. The probabilities, which are what's observable in QT, are given by the matrix elements of the statistical operator. For photons that's described in any textbook on quantum optics. See, e.g.,
J. Garrison and R. Chiao, Quantum optics, Oxford University
Press, New York (2008),
https://doi.org/10.1093/acprof:oso/9780198508861.001.0001
which has a very detailed chapter on photon-detection theory. For photons it's of course the energy density, because there are no charge-like quantum numbers for photons.
as if is a powerful conjunction in physics. E.g. Fermi liquids are fictitious, but under a broad set of conditions, many-body systems behave as if they are a Fermi liquid. We've made all sorts of technological advancements because physicists are willing to premise their understanding of reality (whatever it may be) in these fictions.
Crude but sufficient approximation is something quite different from fictitious.
So both of you say that single systems behave as if they were ensembles. But in an ensemble, the term probability ##p## has a meaning for every ##p## between 0 and 1, while for a single system, only probabilities 0 and 1 have meaning. What meaning do you give the other probabilities?
This is strange since the region under discussion contains a beam, not a vacuum. Since at least sometimes it contains particles, the state of the region cannot be the vacuum state.
But the statistical operator is not an observable. it transforms under time translations not like observables in quantum theory but with a wrong sign. So you cannot apply Born's rule to its matrix elements.
I know how textbook detection theory works, but formulas there are derived there in a piecemeal fashion. I asked for a more fundamental description.
The derivation in the quantum optics books does not start from the state of the lab, which is the fundamental description in qunatum field theory. (If the lab were a single block of ice, you'd also start with the state of the block of ice, and then make approximations to get the standard thermodynamic results.)
Though only incompletely known, we know a large amount about the state of the lab, namely (slightly averaged) values of the effective fields at essentially all points of the lab. This is enough to make the relevant deductions.
vanhees71 said:
See, e.g.,
What is ''it''? Do you mean the energy density replaces the statistical operator? How can that be, given their opposite behavior under time translations? Moreover, unlike the statistical operator, the energy density is not normalizable.
Please be more precise!
For a frequentist interpretation of probability, only 0 and 1 are possible probabilities for a single system. But for a Bayesian interpretation, a single system can "have" any probability in the interval [0,1]. A standard example is flipping one coin only once and not looking at the outcome, in which case the Bayesian probability of heads for one coin is 1/2.
But the physics in a lab does not depend on whether someone looks at the outcome.
In the Heisenberg picture the statistical operator is time-independent. I describe only the particles, and according to your assumption at ##t=0## there are no particles, i.e., the initial statistical operator is the vacuum.
Of course, the time evolution of the stat. op. is different from the time evolution of observable operators. It's more or less arbitrary how you put the time-dependence on the stat. op. and the observable operators. That's the choice of the "picture of time evolution". What's observable are the matrix elements of the stat. op. wrt. the eigenvectors of the observed observable.
The states transform with ##\hat{C}(t,t_0)## according to
$$\hat{\rho}(0)=\hat{C}(t,t_0) \hat{\rho}(t_0) \hat{C}^{\dagger}(t,t_0),$$
where ##\hat{C}## obeys the EoM.
$$\mathrm{i} \partial_t \hat{C}(t,t_0)=\hat{H}_1(t) \hat{C}(t,t_0).$$
The (formal) solution is
$$\hat{C}(t,t_0)=\mathcal{T}_c \exp [-\mathrm{i} \int_{t_0}^{t} \mathrm{d} t' \hat{H}(t')].$$
Where ##\mathcal{T}_c## is the "causal time-ordering operator", ordering operator products with increasing time arguments from right to left.
The observable operators transform with ##\hat{A}(t,t_0)##,
$$\hat{O}(t)=\hat{A}(t,t_0) \hat{O}(t_0) \hat{A}^{\dagger}(t,t_0),$$
where
$$-\mathrm{i} \partial_t \hat{A}(t,t_0) = \hat{H}_2(t) \hat{A}(t,t_0)$$
with the formal solution
$$\hat{A}(t,t_0) = \mathcal{T}_c \exp[+\mathrm{i} \int_{t_0}^t \mathrm{d} t' \hat{H}_2(t')].$$
Finally
$$\hat{H}=\hat{H}_1+\hat{H}_2$$
is the Hamiltonian of the system.
In the Heisenberg picture ##\hat{H}_1=0## and ##\hat{H}_2=\hat{H}##, while in the Schrödinger picture it's ##\hat{H}_1=\hat{H}## and ##\hat{H}_2=0##. The "interaction picture" is the split ##\hat{H}_1=\hat{H}_I## (the "interaction part") and ##\hat{H}_2=\hat{H}_0## (the "free part", i.e., the part in the Hamilton density with is quadratic in the field operators and their derivatives).
You cannot describe the lab quantum mechanically, and fortunately that's not necessary. The description in the quantum optics textbooks is pretty sufficient to explain the high-precision results of quantum-optical experiments.
Indeed. If this were not the case, I doubt that mankind would have ever discovered any "fundamental laws" of nature ;-).
Now, the energy density is not the statistical operator but representing an observable. In classical as well as quantum theory the intensity is physically nothing else than the (time-averaged) energy density of the em. field. Of course the corresponding distribution can be normalized to 1 since the total field energy is always finite.
I try my best. I'm a bit surprised that we have to discuss again the very basics of QT.
OK. But then, since we use the Heisenberg picture, the statistical operator is constant, and your claim
just says that what's observable in QT is given by the vacuum expectation values. Then this is a triviality. (I had misunderstood you, I though you were taking the statistical operator as argument between the vacuum states.) So we can continue. I assume therefore you mean by
that in the case of photons we are looking for the vacuum expectation value of the energy density at different times. But the query is about a silver beam (for further use in a Stern-Gerlach setting). Is here what is observable the vacuum expectation value of the energy density or that of the mass density?
where
Finally
In the Heisenberg picture ##\hat{H}_1=0## and ##\hat{H}_2=\hat{H}##.
This is the textbook treatment for isolated systems. But things are here not so simple since the neighborhood of the beam is not a closed system, and one has to consider the incoming boundary conditions. Otherwise one would never get any signal...
Also some things simplify since we are working exclusively in the Heisenberg picture. To simplify further we may assume that ##t_0=0##.
This is surely false. Why can astronomers describe the sun quantum mechanically but not the much smaller lab? It is composed of the same stuff as the sun, just in a more complex state. We'd therefore be able to get from whatever knowledge we have of that state, quite as in the case of the sun, using techniques like the maximum entropy principle the simplified description used in the quantum optics books by restricting attention to the region of interest, in the present case the surrounding of the beam.
Only to the point where the verbal precision is enough to make clear what you mean.
True, but someone's knowledge about the outcome depends on it. This is what probability means when one uses a fictive ensemble to describe a single system. But that's probably not very important for what really bothers you in this thread. You want an explicit quantum state of the laboratory described by QFT. In practice it's too hard, but in principle I don't see what's exactly the problem with having this state too. If the laboratory is made of ##N## particles, then the state is a product of ##N## creation operators acting on the vacuum, I don't see what's the problem in principle.
Demystifier said:
it's still not clear to me what's your original motivation to study ensembles, do you want to consider a single system or many systems?
The set-up is a single lab containing for 24 hours a source with a very faint beam along which silver particles travel.
I am asking for its complete quantum field description in terms of the Heisenberg state of the lab (restricted to a small, easily analyzable part), in order to be able to discuss how the single silver quantum field of the lab models what is usually discussed in terms of an ensemble of 86400 silver atoms generated by the source in 24 hours.
(This should give a better understanding of what happens on a fundamental level at the screen of a Stern-Gerlach experiment. But for the moment there are no magnets in the setting; thus we do not need to consider spin.)
The Heisenberg state does not depend on time, so it does not depend on the fact that it works 24 hours. You can think of Heisenberg state as the initial state Schrödinger state of the lab. Since the lab is made of atoms, which are made of elementary particles described by QFT, the lab is made of N particles, so the Heisenberg state is described by a product of N creation operators acting on the vacuum. In principle, I don't see what's the problem.
Yes, there should be no problem; I deliberately kept the setting very simple. But this does not mean that nothing needs to be discussed.
We consider explicitly only the part of the lab containing the beam, assuming the beam goes through a perfect vacuum. Restricting the state to this region, it is a vacuum state before the source is switched on. Your creation operators only affect the state at other positions where there is lab matter, hence have no effect on the beam. (This holds since the Hilbert space of the quantum field theory is the completion of a tensor product of the Hilbert spaces of the regions into which one partitions space.)
Thus as long as we exclude what happens at the source (and later at a magnet or a screen) we only need to work with the vacuum state and a free field Hamiltonian. We may ignore the composition of a silver atom (made from elementary particles). Moreover, since silver is heavy, we may use nonrelativistic quantum field theory, so problems with renormalization are absent. This makes the discussion feasible.
Everything that happens is encoded in the Heisenberg equation for the dynamics of the observables. Since the beam is directed along the ##z## axis, the behavior of the source (and hence the detailed properties of the beam) enters solely through the time-dependent ingoing boundary conditions at ##z=0##.
Demystifier said:
@A. Neumaier So do you think that the problem, in principle, is solved now?
Not until the discussion has concluded. We have only begun to discuss the details, and there is a lot to be learnt from studying this simple experiment.
OK. But as a preliminary conclusion, it would be useful if you could pinpoint one or few things which were not clear (to you) at the beginning of this thread, but are clear now.
The statistical operator can of course be everything meeting the conditions, not only the vacuum state. In equilibrium you can use the canonical or grand-canonical statistical operator ##\propto \exp(-\beta \hat{H}+\alpha \hat{Q})##.
It depends on the detector. What you have in mind most probably is described by ##N##-point auto-correlation functions of the charge density.
Sure, but that you can mimic by using some external (classical) source and solve for the operator Klein-Gordon equation (or whatever equation you want to use to describe silver atoms) such that you get your (operator-valued) wave packets with at different times around some place.
More realistic is mimicking the original setup by using a beam of thermal Ag atoms emitted from an oven at temperature ##T##. Then the initial state is the corresponding stat. op. describing this thermal beam coming out of the oven.
A. Neumaier said:
Also some things simplify since we are working exclusively in the Heisenberg picture. To simplify further we may assume that ##t_0=0##.This is surely false. Why can astronomers describe the sun quantum mechanically but not the much smaller lab? It is composed of the same stuff as the sun, just in a more complex state. We'd therefore be able to get from whatever knowledge we have of that state, quite as in the case of the sun, using techniques like the maximum entropy principle the simplified description used in the quantum optics books by restricting attention to the region of interest, in the present case the surrounding of the beam.
Sure, you always have to simplify the description sufficiently to be able to describe anything. The Sun is in a sense simple, because you can describe it as a fireball of plasma in thermal equilibrium held together by gravitation.
I did just this in my post #21.
In general, yes. But in the current experiment you already agreed that the state was the vacuum state.
The detector is a glass bottle, on which I find after sufficient time a faint spot of silver. In this simple experiment, correlations cannot be measured, hence we only need 1-point functions. Since silver is uncharged. I guess you regard the mass as a charge.
Thus do you agree that the correct operator to look at is the mass 4-current, and especially its zero component, the mass density?
Please mimic it for me, so that we can discuss its consequences. Since silver is heavy, I want to use a nonrelativistic QFT, with an antisymmetrized Fock space to account for the spin 1/2 of silver.
But we already agreed that the initial state of the beam is the vacuum state, before the oven is switched on. Since we are in the Heisenberg picture, this will be its state throughout the whole day modeled. Thus you somehow need to get the thermal input into the boundary conditions for the observable of interest.
And the lab is in a local equilibrium state described by the properties of the stuff inside. We are only looking at the region where the beam is, where the state is even simpler - just the vacuum state.
As I said, the switching-on of the oven/any other source of Ag atoms is described by the time evolution of the field operators. The spot on the screen is given by integrating the current ##\langle \vec{j}(t,\vec{x}) \cdot \vec{n} \rangle## (##\vec{n}## is the normal vector of the screen) over time.
Here more details are required. Which time-dependent Hamiltonian are you using?
Note that the oven itself is outside of the spatial domain of the free field describing the beam, and the Hamiltonian inside this domain is independent of time.
Thus the behavior of the source must be in a time-dependent term of the Hamiltonian at the left border ##z=0## of the domain where the beam is modeled.
By assumption, ##\vec{n}## is the unit vector along the ##z## axis. Thus the spot on the screen has intensity distribution
$$I(x_1,x_2)=\int_{t=0}^T\Big\langle \vec j_3(t,x_1,x_2, Z) \Big\rangle dt,$$
where ##Z## is the ##z## coordinate of the point where the beam meets the screen?
