Entanglement swapping, monogamy, and realism
  • Context: Undergrad
  • Thread starter Thread starter kurt101
    Entanglement Realism
This discussion centers on the compatibility of entanglement swapping experiments with realistic interpretations of quantum mechanics, particularly regarding the monogamy of entanglement. Participants reference the paper "Delayed Choice" and argue that while entangled pairs (1,4) exhibit correlations, the timing of measurements (specifically BSM tests) influences interpretations of causation. The consensus indicates that entanglement swapping does not violate monogamy, as the entanglement of pairs (1,4) can be explained through coincidence rather than causation when measurements occur after the BSM test.
  • Understanding of quantum entanglement and its properties
  • Familiarity with Bell state measurements (BSM)
  • Knowledge of realistic interpretations in quantum mechanics
  • Basic principles of quantum field theory (QFT)
  • Study the implications of entanglement swapping in quantum optics
  • Examine the concept of monogamy of entanglement in detail
  • Explore the "Delayed Choice" paper and its arguments in Chapter 4
  • Investigate Bohmian quantum field theory (QFT) and its interpretations
Quantum physicists, researchers in quantum mechanics, and students studying quantum entanglement and its philosophical implications will benefit from this discussion.
  • #211
DrChinese said:
I don't see the range of interpretations as you do. Some continue to assert pre-Bell locality in the face of Bell, without stating exactly what they are giving up in the way of realism. Stated a different way: they present no mechanism as to how locality can be preserved in experiments such as Entanglement Swapping. Certainly the math of QM predicts without regard to spacetime distance.
Most interpretations attempt to maintain Einsteinian causality in all quantum contexts, when the evidence goes against it. That isn't a winning position. I don't know how nature pulls off its tricks, but I know that it displays quantum non-local/non-causal effects.
Three interpretations that preserve locality (not merely local signalling) that have been touched on in this thread:
i) The instrumentalist interpretation: Under this interpretation, quantum theories concern macroscopic preparations and measurements. Whether or not the BSM occurs, the source ##\rho_{14,\mathrm{after}}## will induce the same macroscopic detector responses. It is true that the physicist that performed the BSM can travel to the source and further prepare four new sources, or bin the detector responses into four groups based on their BSM data, but they must do so at sublight speed
ii) The minimalist ensemble interpretation: Under this interpretation, quantum states refer to structureless ensembles of microscopic systems instead of preparation procedures per se. Here, whether or not the BSM occurs, the same ensemble ##\rho_{14,\mathrm{after}}## is produced. You have elsewhere asserted that the ensemble prepared is actually different if the BSM occurs, due to all pairs being entangled. This might be true for some ensemble interpretations (e.g. "PIV" and hidden variable ensemble interpretations) but the minimal ensemble interpretation says nothing about the structure of the ensemble, and so we cannot say the all particles are entangled in the full ensemble. We have to explicitly produce 4 distinct subensembles to recover (14) entanglement (also limited to sublight speeds)
iii) Consistent histories: Consistent histories lets us construct the subensembles of entangled (14) pairs even if the BSM is not carried out. It's just that these subensembles are not accessible to any physicist unless the BSM is performed. Note that this is not a hidden variable interpretation, but the reasons why might take us too far from the topic at hand.
  • #212
When the BSM test is done before measuring 1 & 4, and the BSM test shows maximum entanglement, you can change the polarization angle used in the measurement at 1 and 4 at the very last moment, right before performing the measurement of 1 & 4 and you will still get the maximal entangled correlation between 1 & 4, right? So entanglement between 1 & 4 in this case is just as real as the entanglement in an EPR experiment correct? Does everyone on this thread agree on this?
  • #213
mattt said:
Dr Chinese seems to have problems understanding that a photon-pair can belong to a set (of identically prepared copies) collectively described as a Product State, and at the same time this photon-pair may also belong to a different set (for example, any of the four subensembles) collectively described (each of the four subsets) as a Maximally Entangled State (which are four different states by the way), without necessarily anything "changing" for that photon-pair.
The monogamy of Entanglement apply when you consider a given ensemble (of identically prepared copies), but it ceases to apply if you change the ensemble for a subensemble (if you change the state, that now describes a different collection).
This is completely incorrect. I have quoted extensively on Monogamy and quoted papers. Where are your references?
According to QM: MoE applies to any and every single entangled pair. There is no requirement that there be a large set.
Further: of course you can model a system where you discuss an entangled pair (say 1 & 4) and other particles (let's say 5 & 6, which are not entangled). We would have a Product state with: (1 & 4) and (5) and (6). Unless there is some purpose to such a description, it isn't useful. And certainly has no relevance to our discussion. In our discussion, MoE applies exactly as follows:
If (1 & 2) are maximally entangled in a Bell state, then (1 & 4) are not at all entangled.
Any other application is wrong. And this is what is useful to our discussion.
  • #214
akvadrako said:
I think your view is contradicted by this post-selection swapping experiment
I think you need to look at the actual math, since that's all I was talking about. The results of that experiment, like all experiments done to date to test QM, are perfectly in accordance with the actual math of QM.
akvadrako said:
Are you trying to say that I must accept FTL influences?
Not at all. That's why I said "open to interpretation".
akvadrako said:
the idea that entanglement is statistical correlation instead of an objective property is a self-consistent position to hold.
Statistical correlation is an objective property; you can measure it just like you can measure any other objective property.
If you are referring to an ensemble interpretation of the quantum state vs. an interpretation that says the quantum state describes individual systems, I already referred to that.
akvadrako said:
how can entanglement be objective when it's frame dependent?
Entanglement is not frame dependent. As I have already said, whether a particular quantum state is entangled is an objective property that has a straightforward mathematical test.
I really think you need to look at the math before making any further claims.
akvadrako said:
This paper appears to be highly speculative, and the claim about entanglement being frame dependent contradicts every QM textbook I have ever read.
  • #215
vanhees71 said:
it's not convincing in the application of probability theory to physics.
Many Bayesian physicists (the canonical example would be E. T. Jaynes, but he is hardly the only one) would disagree with you. I suggest reading Jaynes' Probability Theory: The Logic of Science.
vanhees71 said:
In this sense quantum states describe ensembles rather than single realizations of measurements.
Jaynes' viewpoint was that this just means QM is an incomplete theory: there are physical degrees of freedom that are simply missing from its model, which accounts for its inability to make predictions that aren't probabilistic. It's unfortunate that he never (AFAIK) studied the Bohmian interpretation, since that is a famous example of an underlying model that adds degrees of freedom.
  • #216
Nullstein said:
There are 3 systems, B, C and D in the paper. It discusses a general setting. System B corresponds to the 2&3 system in our case and systems C and D correspond to systems 1 and 4 respectively.
That's not what I see in the paper. What I see is two systems, with different letters labeling the systems at different times or after different operations are performed on them. I don't see more than two systems anywhere in the paper. Nor do I see anywhere in the paper where it claims to be talking about more than two systems: I only see section headings and figure captions that say "two systems".
  • #217
Yes, all of this is correct. You could also vary the relative angles of the 1 & 4 measurements to verify that the correlations between them violate the Bell inequalities and match the QM predictions. (In fact, you can do this regardless of the time ordering of the BSM and the 1 & 4 measurements.)
  • #218
This is assuming a non-ensemble interpretation, i.e., an interpretation in which the quantum state describes individual quantum systems.
On an ensemble interpretation, the quantum state only describes ensembles, not individual systems. I have not seen a good discussion of how an ensemble interpretation deals with the theorems on monogamy of entanglement, but if anyone knows of such a discussion in the literature, I think it would be of interest in this thread.
It also might be of interest to see how proponents of ensemble interpretations (e.g., Ballentine) deal with recent experiments in quantum computing and quantum optics, in which quantum states are routinely treated as applying to individual systems when analyzing, for example, the effects of the various quantum gates.
  • #219
If this is your main drive, you have my symphaty. Indeed some focus on the math and avoid seeking a deeper mechanism.
This is however exactly what brought me to a qbism derivative stance. This is why I asked before about your interpretation. It is easier to speak to a different thinker if you understand each others positions.
/Fredrik
  • #220
PeterDonis said:
Many Bayesian physicists (the canonical example would be E. T. Jaynes, but he is hardly the only one) would disagree with you. I suggest reading Jaynes' Probability Theory: The Logic of Science.Jaynes' viewpoint was that this just means QM is an incomplete theory: there are physical degrees of freedom that are simply missing from its model, which accounts for its inability to make predictions that aren't probabilistic. It's unfortunate that he never (AFAIK) studied the Bohmian interpretation, since that is a famous example of an underlying model that adds degrees of freedom.
Although I like Jaynes's pioneering work in the application of information-theoretical methods in statistical physics, I don't think that he is right here. There are no hints at any hidden variables, and QT describes all observations correctly. For me it's incomplete, because there's no consistent description of the gravitational interaction (or, in your favorite interpretation, space-time geometry), but I don't see, where there should be any hidden variables to come for a rescue. Of course, that's speculation.
de Broglie Bohm may be appealing for non-relativistic QM, but I don't see a convincing extension to relativistic QFT. In addition it doesn't add anything that's not also described by the minimal interpretation. It's a nice example for a truely non-local HV theory in the non-relativistic realm, but there "non-locality" anyway is no problem to begin with.
  • #221
DrChinese said:
The scientists in this room use all the information they have to make their conclusions. I would everyone would. And one of those conclusions is that the BSM "causes" the projection of the random Bell State outcome onto the 1 & 4 pairs that were previously unentangled. The issue with the word "causes" is that time ordering doesn't matter. @vanhees71 is technically correct when he cites the "microcausality" condition to say there are no nonlocal causes. That's merely because quantum causality operates much differently than Einsteinian causality, and therefore cannot be applied like Einsteinian causality.
I agree with everything else you said above, and we seem to very slowly converge now on microcausality. The last step is to understand that this in fact IS Einstein causality, i.e., to accept that relativistic local QFT is satisfying relativistic causality by construction due to the fulfilling of the microcausality constraint. "Nonlocality" refers to correlation of far-distantly observed parts of entangled quantum systems but not to an "action at a distance" or any violation of Einstein causality, which simply says that space-like separated events cannot be in a causal relation to each other.
DrChinese said:
Any way you look at it: a BSM here creates an entangled biphoton there. Pretty hard to wave hands and make that result go away. 1 & 4 pairs: Not at all entangled before the BSM (as we all agree), 100% entangled after the BSM (in 1 of 4 Bell States) - which QM predicts.
Of course, that's what all these experiments demonstrate, and it's not only predicted by QM (where we wouldn't have any problem with causality because in Newtonian physics, including QM, time is absolute) but also by local, relativistic QFT!
  • #222
In the minimal interpretation, of course the state also refers to preparation procedures on single quantum states. Otherwise you couldn't even build the ensembles within this interpretation. The randomness, predicted by QT, and the corresponding probabilities refer to the outcome of measurements but not to the preparation procedure, which is a well-defined procedure in the lab for each experiment.
Then "consistent histories" is very misleading. QT refers to experiments that are really done, not to fictitious experiments which may not even be possible to be done from first principles.
  • #223
I think you are not paying attention to what I write. If you have a composite system in an entangled state. Each subsystem (this is already imprecise) is descirebed by its density matrix. If you perform measurement (or not) on one of the subsystems, the density matrix of the other does not change. Denying this is anti-science. The density matrix gives you the satatistics of the results of any measurment you do on the subsystem. Anything more you say about this is usuing implicitlely some interpretation. For example you say that the measurment on one subsystem (in this discussion 2&3) changes the state of the other (the 1&4). This automatically exludes ensemble interpretations, so it is not as you believe interepretation independent.
DrChinese said:
1. If each and every final 1 & 4 pair is identified as to its Bell state, and a Bell test is performed, and a CHSH inequality is violated: they are entangled. There is no interpretation I know of that denies this.
2. Why on earth you think they are not entangled if you throw away the information on the Bell state, I don't know. That is anti-science. There is absolutely no requirement that all entangled pairs after a swap be a single Bell state to consider them entangled.
1. See, you phrased it in a way that excludes ensemble interpretations. If you think of the whole ensemble of 1&4 it is simply not true. What you mean to say then is that the full ensemble consists of four subansembles, which are in their Bell states.
2. Because if you look only at the 1&4 and do whatever measurments you want, you will not see anything to suggest entanglemnt. You need to partition your results into four groups and then look only at each group. But you cannot do that if you don't have the information of the results of 2&3.
  • #225
@Demystifier: given that the state of the whole (1,4) ensemble is also a sum of four different (1,4) Bell-states (before and after, whether we do something to (2,3) or not), I guess that for Bohmian Mechanics you could say that, for the set of millions of (1,4) pairs created in the whole ensemble, there exists a partition in four subsets X, Y, W, Z (25% of the total (1,4) pairs, in each subset), such that if you run a Bell Test exclusively for the (1,4) pairs in X, the Bell inequality will be violated (whether something is done to (2,3) or not).
The same holds for Y, W, and Z.
(We are not able to identify that partition without the help from the (2,3) measurements).
Is this correct?
  • #226
Is this correct?
My guess is that BM doesn't concern itself with ensembles. My guess is that according to BM in the absolute frame one of the measurements (on 23 or 14) happens first and that instantaneously (according to the absolute time) changes something where the other pair is (or will be).
  • #227
Ah, I'm not very cultured in Bohmian Mechanics yet.
I thought that, because the reduced wave function for (1,4) pairs (the state of the whole (1,4) pairs ensemble) is the same (before and after, whether something is done to (2,3) pairs or not) and this is expressible as a sum of its four Bell states, I thought that Bohmian Mechanics (even though it is non-local) would agree with the ensemble interpretation in the existence of that partition (even if we need "external help" to find it).
  • #228
Is this correct?
I think this is correct. But as @martinbn nicely explained, this is not essential for understanding all this from the Bohmian point of view. Even in classical physics there are subensembles with correlations without a cause. But the point is that in classical physics, as well as in Bohmian mechanics without doing anything to (2,3), you cannot extract such subensembles without cherry-picking. On the other hand, when you do something to (2,3), this creates a correlation without cherry-picking, so it seems natural to believe that doing it was the actual cause of correlation. Bohmian mechanics provides an explicit model for this cause.
https://en.wikipedia.org/wiki/Cherry_picking
  • #229
DrChinese said:
4. I am not "admitting" anything, since I have been saying there are 4 Bell states all along. I can spell them out (as I already did in later post #202), if it makes a difference to your understanding. But I think you know the answer already and don't need this:
Yes, you are right that I don't need this, and explicitly knowing this makes things easier for me. Indeed, I wasn't sure how much you would protest about my "lazy" notation:
gentzen said:
... And then, wouldn't ##\hat{\rho'}_{1234}= \frac{1}{4} \sum_{i=1}^4 \hat{\rho}_{14}^i \otimes \hat{\rho}_{23}^i## be a more appropriate formula for the state, as long as no conditioning with respect to the 4 different states is done?
Let me now slightly extend my formula to include the actual "classically recorded" measurement result:
##\hat{\rho'}_{1234,M}= \frac{1}{4} \sum_{i=1}^4 \hat{\rho}_{14}^i \otimes \hat{\rho}_{23}^i \otimes \hat{\rho}_{M}^i##, where M marks the "classical" part of the information. This allows me to give a better formula for the state ##\hat{\rho}_{1234,M}## before the BSM measurement:
##\hat{\rho}_{1234,M}= (\frac{1}{4} \sum_{i=1}^4 \hat{\rho}_{14}^i \otimes \hat{\rho}_{23}^i) \otimes \hat{\rho}_{M}^0##
The only difference to the state after the measurement is that ##\hat{\rho}_{M}^i## has been replaced by ##\hat{\rho}_{M}^0##.
DrChinese said:
5. And why would we want to fail to condition? That would lead us to a completely useless formula. The authors of the paper do the exact opposite, they USE the conditioning to demonstrate entanglement: "Expectation values for the CHSH inequality depending on the outcome, ψ− or ψ+, of the BSM. Each of these values is calculated from four measurements of four photon coincidences integrated over 15000 seconds."
This is actually a good question. The reason why I "wanted to fail to condition" was that I wanted to have a correct formula. Your question caused me to realize that I can also write down an equation which still contains the "classically recorded" measurement result. Then I have at least the choice, whether I want to trace-out that measurement result and thereby "fail to condition", or whether I "want to condition," and then continue with 4 different formulas for the 4 different cases.
Using the information I have is fine for me, even as an instrumentalist. What I object to as an instrumentalist is giving up a local description, just because of some information which is potentially there, but which I personally don't have.
  • #230
gentzen said:
1. This is actually a good question.
2. Using the information I have is fine for me, even as an instrumentalist. What I object to as an instrumentalist is giving up a local description, just because of some information which is potentially there, but which I personally don't have.
1. So I think we're on the same page at this point.
2. This is the position held by yourself and others here. I totally get the desire to preserve locality. But...
a. It does not seem reasonable that you require all of the information about an experiment (with spatial extent) to be available simultaneously (your "because of some information which is potentially there, but which I personally don't have.") Your requirement could never be met when the full context is nonlocal.
b. You must then fully reject the realist position that there are well-defined outcomes independent of the act of observation. So you fully accept subjective (observer created) reality. A lot of interpretations (not saying yours does) that preserve locality try to "sneak by" on this point; "revealing pre-existing correlations" and the like. They can't be pre-existing (if you preserve locality) unless you reject Bell.
c. I don't get why, in experiments like the one we are discussing: The most obvious thing to conclude is that there IS action at a distance - so why not start from that position? I mean, I get that there is the desire to preserve Einsteinian causality. And actually, in the sense that QM predicts action at a distance, there is preservation of Einsteinian ideas in that there is still signal locality. It seems to me there are 2 different spacetime metrics at work. (I am not proposing an interpretation, just attempting to describe what I see.)
i) One limits signals and determinate actions to forward in time cause/effects, which cannot exceed c in any frame. Everyone pretty well agrees on this, regardless of interpretation.
ii) The other allows the full quantum context to be identified in a manner that does defy the apparent limits of relativity, but limits action at a distance to random outcomes. My observation regarding this: Interestingly, the full quantum context itself (which may consist of many elements in spacetime) only includes individual points that can be connected by determinate action limited to c. I will explain this statement in terms of our example.
In our example of entanglement swapping, we have the following basic experimental points in spacetime:
a) The 2 initial PDC sources A (for 1 & 2) and B (for 3 & 4), distant from each other.
b) The 2 Bell test setups for the Bell test on 1 & 4, distant from each other.
c) The BSM setup for determining the Bell state on 2 & 3, distant from the Bell test setups.
Despite the distances between the 2 sources (individually not in a common light cone) and the 3 Bell/BSM test setups (individually not in a common light cone): Each source is connected to one Bell test setup and the BSM by a path that respects c. And that is always the case, regardless of how large the quantum swapping network is (N nodes). There are always paths between the initial elements and the final elements that respect c even though there are other paths that may not - there is no element of the full context that only connected to the rest of the context by a path that does respect c.
Although I believe that our swapping experiment objectively demonstrates action at a distance (the BSM here changes the state of a remote quantum system there): I also see that the nonlocal context is constructed from component paths that individually respect c.
  • #231
a. You must then fully reject the realist position that there are well-defined outcomes independent of the act of observation. (Otherwise you run afoul of Bell, of course.) So you fully accept subjective (observer created) reality. A lot of interpretations (not saying yours does) that preserve locality try to "sneak by" on this point; "revealing pre-existing correlations" and the like. They can't be pre-existing (if you preserve locality) unless you reject Bell.
There is no subjectivity in the ensemble representation. The quantum state tells you the probabilities for the outcome of measurements given the state (preparation) of the system. The non-local correlations, described by entangled states are indeed "pre-existing" due to the preparation of the entangled state, and they are objective. What's strictly local within relativistic QFT are interactions due to the microcausality constraint.
DrChinese said:
b. I don't get why, in experiments like the one we are discussing: The most obvious thing to conclude is that there IS action at a distance - so why not start from that position? I mean, I get that there is the desire to preserve Einsteinian causality. And actually, in the sense that QM predicts action at a distance, there is preservation of Einsteinian ideas in there is still signal locality. It seems to me there are 2 different spacetime metrics at work. (I am not proposing an interpretation, just attempting to describe what I see.)
It's not obvious that there's action at a distance at all. You can obviously use standard QED to account for all observed effects on entangled states, and standard QED by construction has no actions at a distance but it's fully compatible with Einstein causality due to the microcausality constraint implemented in its construction. I don't know what you mean by "signal locality", but if you mean that there are no causal connections between any space-like separated events, then this indeed implies that there are no FTL signals and thus also no actions at a distance. There are no two different spactime metrics at work. We are completely within the realm of special relativity, and there the spacetime geometry is fixed to be a Minkowski space.
But you don't respect it above in saying that it was obvious that there are actions at a distance. This morning I thought, we'd agreed, but now you deny again the mathematical properties of relativistic local QFT.
DrChinese said:
ii) The other allows the full quantum context to be identified in a manner that does defy the apparent limits of relativity, but limits action at a distance to random outcomes. My observation regarding this: Interestingly, the quantum context itself (which may consist of many elements in spacetime) only includes individual points that can be connected by determinate action limited to c. I will explain this statement in terms of our example.
I don't understand, what this is meant to say. There's a concise mathematical frame work, i.e., local relativistic QFT. I think to make this point clear, you have finally use concrete math rather than "many words"!
Yes, and all what's done here is well-described by local interactions between the photons and the equipment used in all these steps of preparation (a), the measurements of polarizations on photons 1 and 4 needed to perform a Bell test later by exchanging the information about the results of these polarization measurements for the subensemble chosen due to the Bell-State Measurement on photons 2&3.
Not again paths! There are no paths of photons. It's confusing and misleading language, as we have discussed several times before.
DrChinese said:
Although I believe that our experiment demonstrates action at a distance (the BSM here changes the state of a remote quantum system there): I also see that the nonlocal context is constructed from component paths that individually respect c.
Once more, you are contradicting yourself in on the one hand acknowledging that everything is described by QED but on the other hand denying that the interactions are local. The only thing that's "non-local" are the correlations between far distantly observed parts of entangled quantum systems, i.e., there are "non-local correlations" but there are NO "non-local interactions" (and thus no FTL signaling and no actions at a distance) thanks to the microcausality condition fulfilled by QED.
  • #232
Franck Laloë in chapter 6 “Quantum entanglement” of his book “Do We Really Understand Quantum Mechanics?”:
6.1 A purely quantum property
In quantum mechanics, the relation between parts and the whole is very special, and certainly non-intuitive. We have already mentioned that Schrödinger was the first to use the words “quantum entanglement” in 1935, when he wrote (page 555 of [233]): “When two systems, of which we know the states by their respective representatives, enter into temporary physical interaction due to known forces between them, and when after a time of mutual influence the systems separate again, then they can no longer be described in the same way as before, viz. by endowing each of them with a representative of its own. I would not call that one but rather the characteristic trait of quantum mechanics, the one that enforces its entire departure from classical lines of thought. By the interaction the two representatives [the quantum states] have become entangled......
Another way of expressing the peculiar situation is: the best possible knowledge of a whole does not necessarily include the best possible knowledge of all its parts, even though they may be entirely separate and therefore virtually capable of being 'best possibly known', that is, of possessing, each of them, a representative of its own. The lack of knowledge is by no means due to the interaction being insufficiently known — at least not in the way that it could possibly be known more completely — it is due to the interaction itself.”
As respects to entanglement swapping, one now has to rethink Schrödinger’s statement as systems can become entangled that have never previously interacted. “Entanglement swapping is a procedure in which entanglement may be 'swapped' from a pair of jointly measured particles to a pair of particles lacking common preparation.” (David Glick in “Timelike Entanglement For Delayed-Choice entanglement Swapping”)
  • #233
Can you provide a reference for this statement? This claim is contrary to pretty much every single reference in the field. Just to make the terminology clear: "pre-existing correlations" does not mean that the individual measurement results are pre-existing, but their correlations are. If you prepare a state of momentum-entangled photons, you will always find that the sum of the two photons sums up to the same value (up to some small uncertainty). If you prepare a state of energy-entangled photons, you will find that their energies always sum up to the same value. This sum of energies (or momenta) is the pre-existing correlation. "Revealing pre-existing correlations" amounts only to conservation of energy (or momentum) and means, e.g., that the sum of the energies of the entangled photons in PDC is equal to the energy of the input photon. In other words, it means that you can predict the sum of the two entangled photon energies in PDC before the experiment is performed if you know the energy of the input photon (but of course not the individual photon energies).
Your statement is equivalent to stating that conservation of energy and momentum do not apply in experiments on entanglement, which is a very strong statement that should be backed up.
  • #234
Cthugha said:
Can you provide a reference for this statement? This claim is contrary to pretty much every single reference in the field. Just to make the terminology clear: "pre-existing correlations" does not mean that the individual measurement results are pre-existing, but their correlations are. ... "Revealing pre-existing correlations" amounts only to conservation of energy (or momentum) and means, e.g., that the sum of the energies of the entangled photons in PDC is equal to the energy of the input photon. In other words, it means that you can predict the sum of the two entangled photon energies in PDC before the experiment is performed if you know the energy of the input photon (but of course not the individual photon energies).
Surely there is no need to provide references for the fact that Bell precludes both locality and realism. A person who holds on to locality must reject realism to comply with Bell. And nowhere do I make any claim whatsoever about conservation rules, and certainly don't reject them. Anything otherwise is not my assertion, and I don't really see how it applies here. I follow orthodox QM and generally reject Bell realism AND accept quantum non-locality (as that what QM looks like to me).
I think the issue here is terminology - I mentioned "pre-existing correlations" and I meant "pre-existing something" where each interpretation fills in the something in order to get to the predicted correlations. There are a number of interpretations that claim - in one fashion or another - that swapping experiments represent an "updating" or "revealing" of pre-existing conditions. If they preserve locality then they must reject realism, but a reading of their tenets is not completely clear on this point. Generally, I would refer to these as "wave function is epistemic" interpretations. Are these interpretations rejecting realism, or not? You asked for references:
1. QBism: Local with epistemic realism (reality is based on user beliefs)
https://arxiv.org/pdf/1810.13401.pdf
Locality: "... when we consider the highly specialized character of what is actually meant by realism in this context, keeping the local turns out to be the natural move."
Realism: "A quantum state encodes a user’s beliefs about the experience they will have as a result of taking an action on an external part of the world."
2. Consistent Histories: Local with epistemic realism (reality is stochastic)
https://plato.stanford.edu/entries/qm-consistent-histories/#LocSpeRel
Locality: "No such nonlocal influences are present in the histories interpretation, which is perfectly compatible with special relativity."
Realism: "First, quantum dynamics is treated as stochastic or probabilistic. ... In other words, given a measurement outcome [mk] at t2 one can be certain that the prior state of the particle at t1 was [sk]."
In their words, not mine. I call this "skirting Bell" because these interpretations do not do a very strong job of rejecting EPR elements of reality (Bell realism). They keep with the idea that there was a single reality prior to the act of measurement.
If anyone here denies the quotes above, I'd be happy to learn more. I don't consider myself well-versed in all interpretations, I mainly know what folks here have told me about there views (and which school they belong to).
  • #235
In the foundations of QM realism means existence of values of observables, not the philosophical existence of objective reality. I think that QM is non realistic by itself. And one needs to work hard to have a realistic interpretation. So rejecting realism (in this sense) is not a problem at all.
  • #236
I think that nobody here has asserted the realistic position (that quantum observables have definite values all the time, regardless of the act of measurement or context) as unavoidable, just the opposite is true.
At most only bohmian mechanics defenders (or any other non-local realistic interpretation) may have mentioned it as a possibility only.
What I (and many others in this thread) have asserted is that this experiment and the mathematics that describes and explains it, adds nothing essentially new to the mathematics of entanglement (the CHSH Theorem and similar ones, the fact that the mathematics of quantum mechanics violates Bell inequalities, quantum teleportation, ...)
In all these cases, the state (the mathematical object that characterizes the statistics of) the initial ensemble of identically prepared copies, shows you that those correlations are there in the mathematical expression of the state, and they will be revealed experimentally if we happen to apply the pertinent experimental procedures suggested by that same mathematical expression of the initial state.
I see nothing new in this sense.
  • #237
I agree with this. The only difference is the part where you say that this experiment shows nothing that wasn't already present before. I think the issue is: A particle (1) that was monogamously entangled with another (2) had its quantum state changed remotely so it was maximally entangled with yet another (4), without ever interacting with any other system at all.
That dynamic is not included in your description. This is relatively new (about 20+/- years), obviously now is well-accepted (the experiment, not necessarily the interpretation that swapping is objectively "action at a distance"). Then there is the PBR theorem (circa 2011), which says the wave function is itself "real".
https://arxiv.org/abs/1201.6554
"Broadly speaking, physicists today view the quantum state in one of two ways: in correspondence with the real physical state of affairs [Ontic] or as representing only an agent’s knowledge or information about some aspect of the physical situation [Epistemic]. The latter ‘epistemic’ viewpoint is primarily motivated by the obvious parallel between the quantum process of instantaneous wavefunction collapse, and the classical procedure of instantaneous updating of a probability distribution, both of which occur upon the acquisition of information regarding the outcome of a measurement process. The epistemic view has a long history of illustrious advocates..." Those advocates including Einstein, Popper, Ballentine, Zeilinger and Spekkens (plus many greats whose names are not mentioned).
Not surprisingly, and despite experimental realization, there are some who don't accept the PBR theorem on a variety of grounds. But when you combine the swapping experiment with the PBR theorem, yes, I think we are in a very new world when it comes to interpretations. If you aren't suitably familiar with these, I think you might want to make sure your favored interpretation complies with these... without hand-waving. :smile:
  • #238
And because the wave function has this aspect of reality, the density matrix is so important to me and other instrumentalists. In fact, only after I learned about the density matrix in the context of partial coherence in optics, did I guess (around 2006) that I might finally be able to understand quantum mechanics, if I would give it a second try. Which turned out to be true.
Scott Aaronson nicely explains what is going on in the PBR theorem: The quantum state cannot be interpreted as something other than a quantum state
I recommend reading the preprint if you haven’t done so yet; it should only take an hour. PBR’s main result reminds me a little of the No-Cloning Theorem: it’s a profound triviality, something that most people who thought about quantum mechanics already knew, but probably didn’t know they knew. (Some people are even making comparisons to Bell’s Theorem, but to me, the PBR result lacks the same surprise factor.)
By contrast, pure states—states with perfect quantum coherence—seem intuitively much more “objective.” Concretely, suppose I describe a physical system using a pure state |ψ>, and you describe the same system using a different pure state |φ>≠|ψ>. Then it seems obvious that at least one of us has to be flat-out wrong, our confidence misplaced! In other words, at least one of us should’ve assigned a mixed state rather than a pure state. The PBR result basically formalizes and confirms that intuition.
  • #239
That blog entry came out very shortly after the original PBR paper, and I would not call it particularly insightful or definitive. Without trying to hype its significance, I would point instead to the 2014 review by Leifer (88 pages).
https://arxiv.org/abs/1409.1570
The original paper has about 1000 citations, and I would call it generally accepted. The significance of it may be in dispute, but not the proof itself. "If the quantum state merely represents information about the real physical state of a system, then experimental predictions are obtained which contradict those of quantum theory." This is an anti-realist position (even as it espouses the reality of the wave function), and I would rate it as fairly severe.
  • #240
I do not see how this is relevant for my remark. It was aimed especially at the term "pre-existing correlations" and your statement "They can't be pre-existing (if you preserve locality) unless you reject Bell."
"Pre-existing something" is ill-defined. Pre-existing correlations are a clear-cut technical term with a well defined meaning: One can take, e.g., Mermin's take from "What is quantum mechanics trying to tell us", where he states:
"By correlations among subsystems I have in mind the mean values, at any given time, of all system observables (hermitian operators) that consist of products over subsystems of individual subsystem observables. Among the observables of a subsystem are the projection operators onto its linear subspaces, so the set of all correlations among the subsystems contains the set of all joint probability distributions over subsystems."
One example of such a system variable that consists of products over subsystems is the sum of the energies of the two detected photons in a PDC process. This sum energy is a correlation in the full technical sense of this word. The value of this sum energy can be predicted beforehand (if the input photon energy is known) with 100% certainty. It is therefore an element of reality. Most importantly, the fact that the correlation (the sum of energies) is an element of reality does not imply that the individual energies are an element of reality as well. This is what inspired Mermin's "Correlations have physical reality. That which they correlate does not".
Therefore, your statement "[correlations] can't be pre-existing (if you preserve locality) unless you reject Bell" is not tenable. The individual values of the photon energies surely cannot be pre-existing in this case. The sum of the values (and therefore the correlations) can. This is trivially not at odds with Bell at all. You can even formulate uncertainty relations about that. Just like you can either prepare states with well-defined momentum or position, you can either prepare states with well-defined correlations (so you have entanglement) or well defined individual properties (so you have some kind of single photon coherence). This has been shown by Teich in his famous 2001 PRA (Phys. Rev. A 63, 063803 (2001), https://arxiv.org/abs/quant-ph/0112065 ).
Just to summarize: my point is that "pre-existing correlations" are not "pre-existing something", but a well-defined technical term that should not be used in a loose manner as its meaning may easily get altered completely when doing so.
  • · Replies 96 ·
  • · Replies 85 ·
  • · Replies 54 ·
  • · Replies 32 ·
  • · Replies 178 ·
9K
9K
  • · Replies 60 ·
  • · Replies 27 ·
