Entire Functions and Lacunary Values.
8 replies · 3K views · last reply
Homework Helper
#Hi All,
Let ## f: \mathbb C \rightarrow \mathbb C ## be entire, i.e., analytic in the whole Complex plane. By one of Picard's theorems, ##f ## must be onto , except possibly for one value, called the lacunary value.
Question: say ##0## is the lacunary value of ##f ##. Must ## f ## be of the form ##e^{g(z)}## , with ##g(z)## analytic?.
Clearly if ##g(z)## has no lacunary values, then ## e^{g(z)}## will have only ##0## as its lacunary value,
and if ##g(z) ## has only ##w## as its lacunary value, then this value will be assumed in ## w+i2\pi n ##, so ##0## will still be the lacunary value of ## e^{g(z)}##. Maybe we can consider composing functions with known lacunary values, but I don't see offhand how, since I don't know the lacunary values of general entire functions.
I considered using Weirstrass factorization thm, but it seems overkill and has led nowhere.
Thanks.
Theorem: Let ##D## be any elementary domain (for example ##D = \mathbb{C}##), let ##f:D\rightarrow \mathbb{C}## be an analytic function such that ##f(z) \neq 0## for each ##z\in D##, then there exist an analytic function ##h## such that ##f(z) = e^{h(z)}## for all ##z\in D##.
Proof: Let ##F## be a primitive of ##f^\prime / f##. Then put ##G(z) = \frac{e^{F(z)}}{f(z)}##. One checks easily that ##G^\prime (z) = 0## for all ##z\in D##. Therefore, ##e^{F(z)} = Cf(z)## for some nonzero constant ##C##. Since ##e^z## is surjective, we can write ##C = e^c##. Then ##h(z) = F(z) - c## does the trick.
Thanks, that shows the side I am aware of, but does it show that all entire functions that do not hit zero are of this form? Sorry, I know I am being lazy and using composition of entire functions would give an answer, but I wondered if someone knew the answer offhand.
They all can be expressed in that way. That's what the theorem says.
Sorry for not being clear: I am looking for a common way of generating/describing all such functions, I would say with an iff rule. I know that every function _can_ be expressed that way. What I meant to say is: does that form exhaust all possible functions with lacunary value 1?. I am looking for something along the lines of ##f: \mathbb C \rightarrow \mathbb C ## is an automorphism (global diffeomorphism) iff ##f(z)= az+b ##. Yes, you are right that any function ##f(z)## with ##f(z)## entire and never ##0## does have a logarithm ## g(z) ## in a simply-connected region so that ## e^{g(z)}=f(z) ## , but what I should have asked is whether this exhausts all possible such functions. Hope I was clearer this time
Let me think it through and I will try to be more clear. Thanks.
"For every entire nonzero non-constant function f there exists g with [property]" is as exhaustive as it can get.
The other direction is also true:
For every non-constant entire g there is a non-constant nonzero entire f with f(z)=eg(z).
