Entropy change for ideal gas heated at constant volume
  • Thread starter Thread starter asdfTT123
    Heating Thermo
1 reply · 3K views
asdfTT123
Problem 1:
An ideal gas is heated reversibly at constant volume from T1 to T2. Calculate the entropy change
of the system, the surroundings, and the universe.
dS = dq/T (reversible change)
and dq = CvdT (constant V)
I know how to do the system:
dS = dq/T, so you can substitute the heat capacity for dq to get
dS = CvdT/T and integrate to get dS of the system to be Cv * ln(T2/T1)
Here is where I'm not sure...
Wouldn't the entropy of the surroundings just be the negative of that? I figure because it's a reversible process the entropy change of the universe is 0...correct? Please correct me on that. Also, is there a better expression or more intuitive solution for the entropy of the surroundings?
Problem 2:
For a particular change of state, why is qrev>qirr? That is, why is heat flow greater for a reversible
change of state rather than when the same change of state is brought about irreversibly?
None that I know of.
Is it because in an irreversible process, heat is often dissipated away in other forms such as work, noise, etc...? Because the system is not in equilibrium for an irr process the heat flow is not always conserved. Is this correct and is there a better explanation for this problem?
Thanks!
I think you are right in both problems.
For problem 2, you might be able to add some more quantitative arguments in terms of the second law.
