Envelope(s) of the Sinc function
  • Thread starter Thread starter greswd
    Function
The envelope function of the sinc function, defined as ##\textrm{sinc}(x) = \frac{\sin x}{x}##, is established as ##1/x## when the carrier oscillation is defined as ##\sin x##. This conclusion indicates that the envelope is intrinsically linked to the carrier function, and any alteration to the carrier would necessitate a change in the envelope function. The discussion confirms that no alternative envelope function exists without modifying the carrier, reinforcing the relationship between the two functions.
  • Understanding of the sinc function and its mathematical representation.
  • Familiarity with oscillatory functions, particularly sine functions.
  • Knowledge of mathematical concepts related to envelopes and piece-wise functions.
  • Basic calculus to comprehend the behavior of functions and their limits.
  • Research the properties of the sinc function in signal processing.
  • Explore the concept of envelope functions in more complex oscillatory systems.
  • Investigate piece-wise functions and their applications in mathematical modeling.
  • Learn about Fourier transforms and their relation to sinc functions in frequency analysis.
Mathematicians, signal processing engineers, and students studying oscillatory functions and their properties will benefit from this discussion.
greswd
What is the envelope function(s) of the sinc function?
Mathematics news on Phys.org
##\textrm{sinc}(x) = \frac{\sin x}{x}##, if you define the carrier oscillation to be ##\sin x##, what would be the envelope?
I was thinking of a function that would also accommodate the central peak and the underside of the central peak?
Does such a function exist, or do I need to use a piece-wise function?
As far as I know, the envelope of a function comes along with the carrier, which is usually defined to be oscillating periodically. In the case of ##\textrm{sinc} (x)##, the carrier according to that definition is the sine and hence the envelope is ##1/x##. I don't think you can find another form for the envelope, without changing the carrier and hence changing the whole function.
alright thanks
10K
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 26 ·
