Epsilon- N Proof a Sequence Diverges
The discussion focuses on proving the divergence of two sequences. The first sequence, defined as x_n = (n^2 - n)/n, simplifies to x_n = n - 1, which diverges as n approaches infinity, since |x_n - L| grows without bound for any finite L. The second sequence, x_n = ((-1)^n + 1)/n, is analyzed by comparing it to the divergent sequence b_n = (-1)^n/n, which oscillates between -1/n and 1/n, thus also diverging. The participants express difficulty in executing proofs of divergence, emphasizing the need to show that for any chosen epsilon, there exists an n such that |x_n - L| exceeds epsilon. Ultimately, the discussion highlights the importance of understanding the behavior of sequences as n increases to determine convergence or divergence.
B3NR4Y
1. Let ##x_n = \frac{n^2 - n}{n} ## does ##x_n## converge or diverge?
2. Let ##x_n = \frac{(-1)^n +1}{n} ## does ##x_n## converge or diverge
A sequence converges if ##\forall \epsilon > 0##, ##\exists N \in \mathbb{N} ## such that ##n\geq N ## implies ## | x_n - L | < \epsilon ##
A sequence diverges if ##\exists \epsilon_{0} > 0##, ##\forall N \in \mathbb{N}##, ##\exists n_{0} \geq N ## such that ##|x_{n_{0}} - L | > \epsilon_{0} ##
For one, I noticed that ##x_n = n-1 ## which obviously diverges. But as my teacher says, I got to prove it. So I take ##\epsilon_0 = \frac{1}{2}, \, \, L \in \mathbb{R}, \, \, n \geq N, \, \, N \in \mathbb{N} ##
1.) \, \, | (N - 1) - L | < \frac{1}{2}, \, \, \, \, \, \, \, \, |((N+1)-1) - L | = |N-L| <\frac{1}{2}
I can apply the triangle inequality to find that ##|N-1-L| - |N-1| \le 1 ##, but I can see from 1.) that ## |N-1-L| - |N-L| < 0 ## Therefore ##x_n## diverges.
Obviously I wouldn't be posting here if that satisfied me, it doesn't. ##|N-1-L| - |N-L|=(-\infty, \, 0) ## would satisfy both of those.
2.) I noticed that ##x_n = \frac{(-1)^n +1}{n} > \frac{(-1)^n}{n} ## so all I should have to do is prove ##b_n = \frac{(-1)^n}{n} ## diverges and that should be sufficient. So if we take ##\epsilon_{0} = \frac{1}{2}, \, \, L = 1 \, \, n\geq N ##, ##|b_{n} - 1| > \epsilon ##, ##b_n = 1## when n is even and ##b_n = -1## when n is odd, therefore ##|-1 -1| = |-2| = 2 > \epsilon## which proves ##b_n## is divergent therefore proving ##x_n## is divergent..
This doesn't satisfy my either, I understanding proving convergence just fine but for some reason I find proving divergence harder.
Well, if a sequence diverges, then there will be some ## \epsilon ## such that, no matter how big an ## N ## you pick, ## n \geq N ## will not make ## |x_n - x | < \epsilon ##. That is, we will have ## |x_n - x| \geq \epsilon ## no matter how big ## n ## gets. Does phrasing it that way help clarify things?
Not particularly, I understand what the symbols mean, but actually executing a proof of divergence trips me up. I've started over on the first one, but choosing the epsilon and then proving that no matter what, ##|x_n - L| > \epsilon ##, confuses me.
For your first series, you noticed that ## x_n = n - 1 ##. So the first few terms of the series (assuming we start at ## n = 1 ##) are 0, 1, 2, etc. Suppose ## \epsilon ## is, say, 1/2. For the sequence to converge to x, we would need all the ## x_n ## for big enough ## n ## to make | x_n - x | < 1/2. We have the opposite situation - if you make ## n ## big enough, | x_n - x | = | n - 1 - x | will get bigger than any finite number you choose!
Oh! Okay, that makes a lot of sense.
For the second one, if we choose epsilon to equal 1
|\frac{(-1)^{n} +1}{n} - L| < 1
If n is odd, ## \frac{L}{n} < 1 ##, which isn't necessarily true for all n. L has to be chosen so that ##\frac{1}{L} > \frac{1}{n}##, but L can't be conditioned by n, it has to be fixed. So it's not looking good for ##x_n##
If n is even, ## \frac{|Ln-2|}{n} < 1##, which isn't true, since Ln - 2 ≥ n, so the fraction ## \frac{|Ln-2|}{n}\geq 1## Therefore ##x_n## diverges.
Write down a bunch of terms of the sequence. Does it look like they are approaching a definite number?
For the second one, no, it's either 0 or 1/n ∀n
But sadly just writing terms isn't sufficient for my professor.
What happens to 2/n when n gets bigger and bigger?
It also goes to zero, oops. So it converges and I have to prove that.
You can't prove something that is false, after all :-) That's why it's good to actually write some concrete numbers and get a feel first.
Likes B3NR4Y
Thank you so much! I understand it better now, for sure. :)
