Equation for a circle in terms of constants A and B
The discussion focuses on deriving the radius R and center (h, k) of a circle that passes through the points (0, a) and (0, b), while being tangent to the x-axis. It is established that R = k = (a + b) / 2, and the x-component of the center, h, is determined to be the geometric mean of a and b. The relationship between the center and the chord formed by the points on the y-axis is crucial, as the perpendicular bisector of the chord leads to the center's coordinates. The final equation derived is (b + a)² / 4 = x² + (b - a)² / 4, which allows for solving h definitively.
  • Understanding of circle equations, specifically the standard form ((x-h)² + (y-k)² = R²)
  • Knowledge of geometric properties of circles and chords
  • Familiarity with the concept of geometric mean
  • Basic algebraic manipulation skills for solving equations
  • Explore the derivation of the geometric mean and its applications in geometry
  • Study the properties of chords and their perpendicular bisectors in circles
  • Learn about the relationship between tangents and circles, particularly in coordinate geometry
  • Investigate further applications of circle equations in real-world problems
Students studying geometry, mathematics educators, and anyone interested in the properties of circles and their applications in coordinate systems.
RaoulDuke
If 0<a<b, find the radius R and center (h,k) of the circle that passes through the points (0,a) and (0,b) and is tangent to the x-axis at a point to the right of the origin.
((x-h)^2) + ((y-k)^2)=R^2 (equation of the circle centered around (h,k))
I already showed that R=k=(a+b)/2, which accounts for both the radius R and the y-component of the center of the circle. However, I'm having some trouble discovering h, the x-component of the circle center, in terms of a and b.
I also know that k>h. Is there some way I can use the arc length of a quarter of the circle as a hypotenuse for a right triangle using R and h as the height and base, respectively?
I don't think you can do anything with that.
I would look at the triangle formed by (0,a) and (0,b) and the center of the circle. You know all the sides of that one.
Since the circle passes through (0, a) and (0, b), both on the y-axis, then that line is a chord. The perpendicular bisector of any chord passes through the center of the circle so we know that the y component of the center is (a+ b)/2. Also, the distance from that midpoint of that chord to either point is (b-a)/2.
Let "x" be the x component of the center. The distance, squared, from the center to (0, b) is x^2+ (b- (b+a)/2)^2= x^2+ (b-a)^2/4. Since the circle is tangent to the x-axis, the distance from the center to that point of tangency is just the y-component, (b-a)/2. Squaring that, we must have (b+a)^2/4= x^2+ (b-a)^2/4[/math] since each side is a radius, squared. Solve that for x and the rest is easy.<br /> <br /> Interestingly, the x component of the center turns out to be the geometric mean of a and b!
  • · Replies 16 ·
  • · Replies 62 ·
10K
