Equation of a plane given 3 points
  • Thread starter Thread starter MrB3nn
    Plane Points
MrB3nn
Hello, as part of a flux integral question in 3-d, I need to work out the equation of one side of a pyramid, of which the centre of the base is at the origin of the co-ordinate system.
The points setting out the side I am considering are B(L/2,L/2,0) A(L/2, -L/2,0) C(0,0,L) in cartesian co-ordinates. Basically, the pyramid has sides of its base of length L and height L.
I worked out the 2 vectors corresponding to the edges of the plane, that converge at point C:
C->B=(L/2)i+(L/2)j-Lk
C->A=(L/2)i-(L/2)j-Lk
I did the cross product to get the normal vector:
n=L2i+(L2/2)k
I then tried using the method in which you multiply the vector component from the normal vector by the corresponding cartesian variable, minus the co-ordinate of which ever point you are looking at.
It looks something like this:
For a normal vector V= Vxi + Vyj + Vzk
and a point (A,B,C) the surface would be
Vx(x-A)+Vy(y-B)+Vz(z-C)=0
This is where I am stuck. If I follow this method, this leads me to believe that I multiply the y component of the plane equation by zero (since the vector y-component is non-existant). This is obviously incorrect since there are many points on this plane with y co-ordinates. Can anyone tell me what I am doing wrong? I could work out a unit normal vector but using the above method it shouldn't make a difference since all variables will be scaled by the same 1/magnitude. I tried doing this all again for another point (A) and found the same problem. Please help.
You did it right so far. Your plane ABC is perpendicular to the xz plane, and the equation will be of the form ax+cz=d.
If a point has x and z coordinates that satisfy this equation ax+cz=d, then the y coordinate can be anything (as opposed to "nothing" which you seem to be thinking.
Thanks for your post dude, I see now. It worked, I checked with the divergence theorem and got same answer.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
