Equation of a plane that is parallel to yz-plane
  • Thread starter Thread starter Rawhem
    Parallel Plane
The vector equation of a plane that contains the point P(2,-3,0) and is parallel to the yz-plane can be expressed as Pi: r = P(2,-3,0) + t(0,1,0) + s(0,0,1), where s and t are real numbers. An alternative representation, Pi: r = P(2,-3,0) + t(0,1,1) + s(0,1,2), is also valid but may lead to confusion regarding its parallelism to the yz-plane. To prove that the second representation is indeed parallel, one can demonstrate that the direction vectors (0,1,1) and (0,1,2) are linearly independent and that their cross product is a multiple of each other, confirming the plane's orientation.
  • Understanding of vector equations in three-dimensional space
  • Knowledge of direction vectors and their role in defining planes
  • Familiarity with linear independence and cross products
  • Basic concepts of parallelism in geometry
  • Study the properties of vector equations in three-dimensional geometry
  • Learn about linear independence and how to determine it using matrices
  • Explore the concept of cross products and their applications in vector analysis
  • Investigate the geometric interpretation of planes and their equations
Students studying vector calculus, geometry enthusiasts, and educators teaching three-dimensional geometry concepts.
Rawhem
Find the vector equation of a plane that contains the point P(2,-3,0) and is parallel to the yz-plane
Vector equation is in the form... Pi: r = point + t(u) + s(v) s,t element of real numbers
We know that the direction vectors (u and v) for a plane parallel to the yz-plane don't have x = 0 (no x component).
So the simplest answer to this would be...
Pi: r = P(2,-3,0) + t(0,1,0) + s(0,0,1) s,t element of R
However, another possible answer would be...
Pi: r = P(2,-3,0) + t(0,1,1) + s(0,1,2) s,t element of R
Although the second answer is a little more complex, it defines a plane that is parallel to the yz-plane.
However, my teacher insists that the plane I defined (second answer) isn't parallel to the yz-plane. Is there some way for me to prove that it is? (I am trying to explain my visualization to her but she is very insistent that my answer is wrong).
A plane is parallel to the yz plane if it's tangent vectors are normal to the x unit vector (1,0,0). Show that's true for dPi/ds and dPi/dt. And also show (0,1,1) and (0,1,2) are linearly independent, just to make sure you've got a plane and not a line.
Note, by the way. that, in two dimensions, a line that is "parallel to the x-axis", that is, parallel to the line y= 0, is of the form y= c for some number c. Similarly a line that is "parallel to the y-axis", that is, parallel to the line x= 0, is of the for x= c for some number c.
In three dimensions, the "xy-plane" is the plane z= 0. Any plane parallel to it has equation z= c for some number c.
Thanks for everyone's help!
The way I proved it to my teacher is by showing that the cross product of the direction vectors of each plane are a multiple of each other.
e.g. n1 = dir1 x dir2
n2 = dir2 x dir3
if n1 = kn2 then Pi: r1 = t(dir1) + s(dir2) is parallel to Pi: r2 = a(dir2) + b(dir3)
To make it parallel to the yz plane you just need x constant. To pass through the given point the constant must be 2. So the generic form is (2, s, t).
n2 = dir2 x dir3
Actually, the simplest way to define the cross product is to define \vec{i}\times \vec{j}= \vec{k}, \vec{j}\times\vec{k}= \vec{i}, \vec{k}\times\vec{i}= \vec{j} (i.e. cyclically) and extend to all vectors by defining it to be both "linear" and "anti-commutative".
  • · Replies 21 ·
45K
