Equation of a surface
  • Thread starter Thread starter Miike012
    Surface
The equation of the surface defined by the condition that the distance from point P to the plane y = 1 is twice the distance from P to the point Q(0,-1,0) is derived as follows: Let P be an arbitrary point (x,y,z). The distance from P to the plane is |y - 1|, and the distance from P to Q is √[x² + (y + 1)² + z²]. Setting up the equation |y - 1|² = 4[x² + (y + 1)² + z²] leads to the final equation of the surface, which is an ellipsoid centered at (0, -5/3, 0).
  • Understanding of three-dimensional geometry
  • Familiarity with distance formulas in Euclidean space
  • Knowledge of ellipsoids and their equations
  • Basic algebraic manipulation skills
  • Study the properties and characteristics of ellipsoids in 3D space
  • Learn how to derive equations for surfaces based on distance conditions
  • Explore the implications of geometric transformations on surface equations
  • Investigate the applications of ellipsoids in physics and engineering
Mathematicians, physics students, and anyone interested in advanced geometry and surface equations will benefit from this discussion.
Miike012
Question:
a surface consists of all point P such that the distance from P to the plane y = 1 is twice the distance from P to the point Q(0,-1,0). Find the equation for this surface and identify it.
Solution:
the plane y = 1 is all point (x,y,z) such that y = 1.. So can i label an arbitrary point on the y plane (x,1,z)?
I will label the point (x,1,z) Point G
and i will assign the ordered triple (x0,y0,z0) to Point P
If that step if valid I then came up with the following equation...
|PG|2 = (2|GQ|)^2.
Next I proceeded to solve for x0,y0,z0 for LHS which should give me the equation of the surface...
Is this correct?
I hope my explanation to my solution is understandable
Miike012 said:
Question:
Solution:
|PG|2 = (2|GQ|)^2.
Is this correct?
Without seeing your work, I can't tell whether it is correct. It might be as long as there are no ##x_0\, y_0\, z_0## in your equation. You have the general idea. But I would start by labeling an arbitrary point on the surface by ##P=(x,y,z)##. Then the closest point on the plane ##y=1## is ##(x,1,z)##. Then do what you did. No subscripts needed.
letting ##P=(x,y,z)## the distance from P to the plane y = 1 is
|y - 1|
Distance from P to Q(0,-1,0) is
√[ x2 + (y+1)2 + z2]
Now from the problem we know that
|y - 1|2 = 4([ x2 + (y+1)2 + z2)
y2 - 2y + 1 = 4x2 + 4y2 + 8y + 4 + 4z2
-3y2 - 10y - 4x2 -4z2 = 3
-3(y + (5/3))2 - 4x2 - 4z2 = 3 - (25/3) = -16/3
(Divide by - 16/3)
9/6(y + (5/3))2 + 3/4x2 + 3/4z2 = 1
The equation satisfying the above problem is an ellipsoid with center (0,-5/3,0)
