QuarksAbove
- 8
A particle of mass m is in a harmonic oscillator potential with spring constant k. An observable quantity is given in the Schrödinger picture by the operator:
Z = a^{\dagger}a a^{\dagger} a
a) Determine the equation of motion of the operator in the Heisenberg picture
b) Solve the equation of motion to calculate the form of Z as a function of time.
i\hbar \frac{dZ(t)}{dt} = [Z(t),H]
Z(t) = U^{\dagger}ZU
U = e^{-iHt/\hbar}
<Z>_{t} = <\psi(x,0) | Z(t) |\psi(x,0)>
a)
From a textbook, it said the equation of motion for a time-independent operator (Schrödinger picture) in the Heisenberg picture is:
Where I am assuming H = \frac{p^2}{2m} + 1/2kx^2 because it's a harmonic oscillator.
Is that it for this part of the problem? Just write it down? Seems a bit silly to me.
b)
This part is confusing to me. It asks for me to solve the equation of motion to get Z as a function of time. However, can't I just use
U = e^{-iHt/\hbar}
to obtain Z as a function of time? I assume this because I know with the creation and annihilation operators, I can act on <\psi(x,0)| to (if I assume the ground state) eliminate some operators in Z(t).
Okay so this is the method I think I should go with??
writing out the last equation above, I get:
<Z>_{t} = <\psi(x,0) | U^{\dagger}ZU|\psi(x,0)>
<Z>_{t} = <\psi(x,0) | U^{\dagger}a^{\dagger}a a^{\dagger} aU|\psi(x,0)>
now I am stuck and not convinced i am going about this problem correctly.
