Equation of motion of a mass-spring system
The equation of motion for a mass-spring system is derived from Newton's second law, represented as mx'' + kx = 0, where m is mass, k is the spring constant, and x is displacement. The correct formulation ensures that the acceleration x'' is negative when the displacement x is positive, maintaining consistency in direction. The fundamental relationship is expressed as F = ma, and any modifications to this relationship must be avoided to ensure accurate results. The discussion clarifies the importance of sign conventions in the derivation of the equation.
  • Understanding of Newton's second law (F = ma)
  • Familiarity with basic concepts of harmonic motion
  • Knowledge of spring constants and their role in oscillatory systems
  • Ability to interpret differential equations in physics
  • Study the derivation of the differential equation for harmonic oscillators
  • Learn about the implications of negative and positive signs in physics equations
  • Explore the concept of damping in mass-spring systems
  • Investigate the relationship between mass, spring constant, and oscillation frequency
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of oscillatory systems will benefit from this discussion.
mech-eng
hi, all. I am trying to derive the equation of motion of a mass spring system without using the
energy method but I am wrong somewhere and I can't find it, can you help me find where I am
wrong. Equation of motion of a simple mass spring system is indeed mx''+kx=0 but here I am
thinking that when we pull the mass, motion arises from the spring force which is trying to bring back the mass and it is -kx due to our choice of negative direction but when the force is negative,
i.e -kx, the acceleration x'' must also be negative because they are in the same direction and sense. Here their sense both are negative. So equation should be -mx''=-kx(sum of forces equal mass product acceleration) and thus -mx''+kx=0 Can you explain me where I am wrong?
Exactly. Therefore, writing
\ddot{x} = \frac{-k x}{m}
ensures that the acceleration ##\ddot{x}## is negative when the displacement ##x## is positive. If you add a minus sign in front of ##m \ddot{x}##, you get a positive acceleration for a positive displacement.
I should also add that the base formula is ##F=ma##. Once you have figured out what ##F## is, the equation must be applied directly, without modifying the ##ma## part.
It is very clear, thanks a lot.
