Equations with dependent variable missing
  • Thread starter Thread starter Joseph1739
    Variable
The discussion revolves around solving the differential equation 2t²y'' + (y')³ = 2ty' using the substitutions v = y', v' = y'', and dy/dt = v. The user encounters difficulties in finding the integrating factor, which is suggested to be v - 3, leading to the transformed equation 2t²v' + (v³) - 2tv = 0. It is noted that the equation can be recognized as a Bernoulli equation, which simplifies the solving process. The conversation highlights the need for dimensional consistency and the use of exact equations, emphasizing that the current formulation is not exact due to the mismatch in partial derivatives. The discussion concludes with a reference to Bernoulli equations and their solvability.
Joseph1739
Information from the book:
Use
1. v = y'
2. v' = y''
3. dy/dt = v
to solve the differential equation.
Question: 2t2y'' + (y')3 = 2ty'
I'm stuck at finding the integrating factor (which my book tells me is v-3 in the solutions.)
Using the information above:
2t2v' + (v^3) - 2tv = 0
M(t,v) = v3 - 2tv
N(t,v) = 2t2
Mv = 3v2 - 2t
Nt = 4t
Since these two are not equal, I have to find an integrating factor, but using both:
(1) dμ/dt = [(Mv-Nt)/(N)] * μ
(2) dμ/dv = [(Nt-Mv)/(M)] * μ
both result in a unsolvable equation because I end up with both t's and v's in the equation.
I'm not familiar with this M, N, notation, so I cannot follow your method.
I would start by considering it dimensionally. If v is dimensionally some power n of t, what value of n makes the equation dimensionally consistent? That should suggest a change of variable that simplifies it a bit.
See how you go from there.
The equation ##2t^2v'-2tv=-v^3## can be written as ##v'-\frac{v}{t}=-\frac{v^3}{2t^2}## , that is a Bernoulli equation of type:
## y'(x) + f(x)y=g(x)y^{n} ##
here ##n=3, x=t, y=v, f=-\frac{1}{t}, g=-\frac{1}{2t^2}##. To solve it see the link
https://en.wikipedia.org/wiki/Bernoulli_differential_equation
The equation 2t^2v'= 2tv- v^3 can e written 2t^2 dv= (2tv- v^3)dt and then 2t^2dv+ (v^3- 2tv)dt. Many textbooks write the "generic" first order differential equation M(x,y)dy+ N(x,y) dx= 0 or, with variables v and t rather than y and x, M(v,t)dv+ N(v,t)dt.
Further, such an equation is "exact" (and so particularly easy to solve) if and only if \frac{\partial M}{\partial x}= \frac{\partial N}{\partial y} or, in terms of v and t, \frac{\partial M}{\partial t}= \frac{\partial N}{\partial v}. That is where Joseph1739 got "M= 2t^2" and "N= 2tv- v^3. Of course, as he pointed out, \frac{\partial M}{\partial t}= 4t\ne 2t- 3v^2= \frac{\partial N}{\partial v} so this is not an exact equation.
  • · Replies 16 ·
9K
