Solving Equation 5n*[(2i)^(n-1)]=11520: Find n=? (Answer: n=9)
  • Thread starter Thread starter transgalactic
To solve the equation 5n*(2i)^(n-1) = 11520, it is established that n must be a positive integer. The complex number i complicates the use of logarithms, making trial and error a practical approach. By recognizing that n-1 must be a multiple of 4 for the expression to yield a positive real number, the solution narrows down to n = 9. Testing values shows that when n = 9, the equation holds true, confirming it as the only positive solution. Thus, the answer is n = 9.
transgalactic
5n*[(2i)^(n-1) ]=11520
n=?
the answer in the book is n=9
notice i = (-1)^0.5
how do i solve this equation
i tried to solve it in many ways including logarithims
but log and i (complex numbers)
i don't know if its legal to do
any way i didnt study this logarithims of i (complex numbers)
so i don't think that this is the right way.
please help
n=?
notice i = (-1)^0.5
please help
Of course, 5n(2i)n-1 is the same as 5n(2n-1)(in-1). But i to any power is one of i, -i, -1, and 1. Since the right hand side of the equation is a positive real number, in-1 must be equal to 1. This equation is exactly the same as n (2n-1)= 11520 (with the provision that n-1 must be a multiple of 4 so that the power of i is, in fact, +1). You still are not going to be able to solve that equation using logarithms- you have n both inside and outside a logarithm.
But since n must be a positive integer, there is nothing wrong with "trial and error"- it's just a little tedious. If n=1, then n-1= 0= 4(0), but obviously 5(1)(20)= 5 is NOT 11520. Okay, try n-1= 4, the next multiple of 4, so n= 5. Now 5(5)(24)= 25(16)= 400, not 11520. The next multiple of 4 is 8:if n-1= 8, then n= 9. 5(9)(28)= 45(256)= 11520. Got it!
are you sure that there is no other way?
because i don't think that my teacher would like this
trial and error technic
I agree with HOI, trial and error is the way to go. But, you can severely limit the possible values of n by simply looking at the original statement.
5n \cdot (2i)^{n-1} = 11520
Now, if we assume n > 0 then 5n > 0, and therefore, so must the exponential. But, this will only occur for multiples of 4 plus 1. In other words:
n = 4m + 1 for some m = 0, 1, 2,...
A quick check of these values will land you an answer at m = 2, and thus, n = 9. Since the absolute value of the expression on the left is increasing without bound for n > 0, this is the only positive solution.
If, on the other hand, we assume n < 0, then 5n < 0, and therefore, so must the exponential. This will only occur for multiples of 4 minus 1. Thus:
n = 4m - 1 for some m = 0, -1, -2,...
However, note that for m = 0, we get a value of 5/4, and that for larger values of m, this result must be smaller. Therefore, there are no negative solutions.
thank alot
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
23K
