Equilateral Triangle Complex Numbers Problem
  • Thread starter nighthelios
    Complex
nighthelios
it's ic a problem on comlex numbers
IF z1 ,z2 ,z3 are vertices of equilateral triangle in argand plane
then
P.T.
z1*z1 + z2*z2 =z1*z2
i have 1 soln but it's not tat satisfactory :confused:
then
P.T.
Why doesn't z3 appear anywhere in the equation you're trying to prove?
cos we have to eliminate z3
No, it's because either you wrote the question wrong or the question given to you was stated wrong. What you've asked to prove is impossible to prove, because it's false in general.
One example would be to take the vertices of the equilateral triangle to be the cube roots of 1: 1, [itex]-\frac{1}{2}+i\frac{\sqrt{3}}{2}[/itex], and [itex]-\frac{1}{2}-i\frac{\sqrt{3}}{2}[/itex]. If we take z1= 1, z2= [itex]-\frac{1}{2}+i\frac{\sqrt{3}}{2}[/itex], then z12+ z22= [itex]\frac{1}{2}-i\frac{\sqrt{3}}{2}[/itex] which is not z1z2!
Go back and check exactly what it is you are asked to prove.
Or take z1 = 0, z2 = anything else, and z3 any of the two points in the plane that would make z1, z2, z3 an equilateral triangle.
