Calculate Equilibrium Constant of 2BrCl <=> Br2 + Cl2
The equilibrium constant for the reaction 2BrCl <=> Br2 + Cl2 is calculated to be Kc = 16. In a 5-liter vessel, 0.9 moles of BrCl were heated, resulting in 0.4 moles of Cl2 and 0.4 moles of Br2 at equilibrium. The remaining amount of BrCl is 0.1 moles, which is crucial for the calculation. The volume of the vessel does not affect the equilibrium constant since the concentrations cancel out in the equation.
  • Understanding of chemical equilibrium concepts
  • Knowledge of equilibrium constant calculations
  • Familiarity with stoichiometry in chemical reactions
  • Basic principles of concentration in moles per liter
  • Study the derivation of the equilibrium constant expression for various reactions
  • Learn about Le Chatelier's principle and its application to equilibrium systems
  • Explore the effects of temperature and pressure on equilibrium constants
  • Investigate the concept of reaction quotient (Q) and its relation to Kc
Chemistry students, educators, and professionals involved in chemical engineering or research who require a solid understanding of equilibrium constants and their calculations.
markosheehan
bromine monochloride dissociated on heating the following equation
2BrCl <=> Br2 + Cl2
.9 moles of BrCl were heated in a 5 liter vessel until equilibrium was established . the amount of free chlorine in the mixture was found to be .4 moles
calculate the equilibrium constant for the reaction.
i thought this would be the answer kc=(.4*.4)/(.8)^2
if there are .4 moles of cl2 there must be .4 moles of Br2
there are 2 moles of 2BrCl for every mole of cl2 so there must be .8 mole of BrCl
sadly this does not give the right answer which is kc=16
Mathematics news on Phys.org
Careful here.
We are indeed dealing with 0.8 moles of $\ce{BrCl}$.
But those 0.8 moles of $\ce{BrCl}$ were dissociated in the reaction $\ce{2BrCl <=> Br2 + Cl2}$.
It means that from the original 0.9 moles, there are 0.1 moles left.
So in equilibrium we have 0.1 moles of $\ce{BrCl}$, 0.4 moles of $\ce{Br2}$, and 0.4 moles of $\ce{Cl2}$.
That makes the equilibrium constant:
$$K_c = \frac{0.4\cdot 0.4}{0.1^2} = 16$$
thanks.
isnt the concentration always supposed to be in moles per liter so should we divide by 5 as its in a 5 litre vessel. the answer at the back of the book is 16 though.
the next part of the question is explain why it is not necessary to know the volume of the solution when calculating the equilibrium constant.
i am not sure what i should say.
markosheehan said:
thanks.
The divisions by the volume cancel in this case, because we have the same number of molecules on both sides of the equation.
With concentrations in mole per liter the equilibrium constant is:
$$K_c = \frac{\frac{0.4\text{ mol}}{\cancel{5\text{ L}}}\cdot \frac{0.4\text{ mol}}{\cancel{5\text{ L}}}}
{\left(\frac{0.1\text{ mol}}{\cancel{5\text{ L}}}\right)^2} = 16$$
  • · Replies 19 ·
